Question about Canon MF8180C Color Laser MFC Printer
CANON MF 8180C ERROR CODE 021
hello I have a canon 8180c with an error code e021 idont have a manual also the dealer dont know. Another problem on a canon mx 310 mfc comes up with check printer 6000. please help .Thanks and Best Regards Ansari Ali. Trinidad and Tobago
IB4G2008
  • 3587 Answers
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
that's not too good...let's get down to cases here
Posted on Mar 04, 2008
SOURCE: reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Posted on Oct 01, 2008
wayneard
  • 1901 Answers
SOURCE: replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
Posted on Mar 30, 2009
SOURCE: Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Posted on Apr 07, 2009
  • 39 Answers
SOURCE: how to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Posted on Apr 28, 2009
I need driver for my Canon mf 8180c
You can download the drivers for Canon MF8180C from the Official Canon support site and install you printer.
Click here - Click the 'Drivers & Software' - Select the Operating System and you will get the required drivers and software
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Error code E021
I think that E021 is caused by the rotating unit not rotating or the sensor that detects the rotation is not working. check to make sure that all the colour units are in correctly and not stopping the rotation or maybe something else obstructing it.
Oct 15, 2010 | Canon LBP 2410 Laser Printer
I have canon i-sensys MF 8180c with error E022. It cannot work and i would like to know what does it mean?
developing rotary drive mechanism fault Check the connector of the developing rotary drive sensor.
Check the connector of the drive motor.
Jun 17, 2009 | Canon Office Equipment & Supplies
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
How to fix canon code E071
"hi there
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Looking for scanning software that will work well with Vista 64, and a Canon MF 8180c. A printer driver came with a scanner driver, which works with paint. But I am looking for a ADF friendly software...
problem is, the toolbox utility (scanning) from canon is not recognizing my 8180c, even though i just dwnd fresh driver from canon for local printer. (toolbox is a wired utility.) so no answer, just bewilderment. used to work!..
Nov 12, 2008 | Office Equipment & Supplies
Canon C2100 copier going into a E021 error code and display says drum yellow
Make sure you have the developers correctly installed ... E021 means you have a rotary error.....
Jun 27, 2008 | Office Equipment & Supplies
Canon MF8180C Color Laser MFC Printer Logo
397 people viewed this question
old marine
old marine
