Question about Maytag PYE2300AY Electric Dryer
Does anyone know where the trermal fuse is located on a maytag PYE4558ayw dryer
There are actually two thermal fuses. One on the heating element and then one on the blower housing. This is located on the bottom right front of the dryer which means the front has to come off. If you've gotten the top off the front is a piece of cake
Posted on Jan 31, 2009
    Problem Solver:
  • 12 Answers
There are a couple of things call heat sink located on the dryer under the top case follow diagrams or the wire on heat sinks and it will lead u to the fuse
Posted on Jan 30, 2009
    Sergeant:
  • 311 Answers
Yes if you pop the top, the thermol fuse is on the side of the element.it is small and has two white wires too it.your dryer would be dead if it is open.also i recomend you cleaning the filter housing and your home ducting if that fuse is open[bad] God bless i'll be there if you need more help,by way of email tom
Maytag dryer PYE4558AYW coils heat up then go out.
Sounds like the "cycling thermostat" is bad. Check it for continuity. Here is the part to order in case it is bad.
Nov 10, 2012 | Dryers
Can anyone please tell me where the thermal fuse is located for a Maytag Neptune MDE9700AYW
Hello Tom, welcome to FixYa.
I'll start by saying your post indicates it is a Maytag MDE9700AYW dryer. I'm not sure if you know this, but this particular Maytag is built by Samsung.
To address your question as to where the thermal fuse is located on your dryer, it is one the heater housing, there is a hi-limit and a thermal fuse. If the Thermal fuse/safety is gone, replace the hi-limit as well.
Here is a chart to identify which thermostat is which and it's location, the resitance value to check for and part number for replacement.
Once you've gain access to them you'll need to remove at least one wire to check the continuity...the values are shown in the above chart (basically it's either open or closed)
As far as part, there are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
Let me know how you make out or if you require further assistance and I'll do whatever I can. Good luck.
Regards,
Macmarkus :)
Sep 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Hi. I have a Maytag dryer model PYE4558AYW. It's not wanting to stay on. When i try to turn it back on it won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Jan 02, 2010 | Maytag PYE2300AY Electric Dryer
How do i open the dryer to replace the belt?
use a putty knife slide it between the top and dorr panal
on each side you will feel a stop thats the "dog"
push it back with the putty knife
when both have been popped, the top will pop open
onecs inside you will see two 5/16 bolts holding the front on
2 things, remember how the tumbler sits on the back of the door, for reinstall
unplug before you open
once open it should be fairly easy
Oct 15, 2009 | Maytag PYE4558A Electric Dryer
MAYTAG DRYER PYET444AYW HAS NO POWER...IS THERE AN INTERNAL FUSE?
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Jul 21, 2009 | Maytag Neptune MDE4000 Electric Dryer
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE4558AYW
I bought the thermal fuse kit for this dryer (2 THERMAL FUSES)and replaced both of them. It came with an extra fuse for a gas dryer. It now works fine. Lift the top open. One is toward the rear of the dryer, the other is below the heating element as the other solution said.
Jun 27, 2008 | Maytag PYE4558A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
132 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
