Question about Hitachi 53FDX01B 53" Rear Projection Television
Red convergence not aligning
I just replaced the convergence IC's with 150's but my red convergence doesn't align. When you go to the convergence menu, the red line is off to the right by a good couple inches and I cannot bring it over to where it needs to be, nor can I adjust the other colors over to it. What is the deal?
  • kingnutin Mar 15, 2009
    I appreciate the response, but I forgot I had this posted. The problem was actually the magnetic collar on the red gun had gotten rotated. Now the color lines up good on most of the screen, but the outside edges are kinda... fishbowled. Not knowing enough history on this set, since I got it broken with no info, it's hard to figure what else could be wrong.
  • Hitachi Master
  • 3,459 Answers
Did you replace the resistors. If not you should have bought a complete kit from www.TvRepairKits.com instead of just the 150's.
Posted on Mar 15, 2009
Hello, My main color were out of alignment, as per instruction on manual. I pressed the button for digital array and proceded to align the blue color, then I proceded to align the red color but I could...
The red convergence IC has failed. There are I believe 3 total convergence IC in your tv. The prefix for all three is STK392-xxx. If you can solder you can try and replace yourself otherwise you need a tv tech. With Hitachi's sometimes some critical resistors will change value as well and have to be replaced with exact equivalents. Sorry wish it was an easy solution..
Oct 17, 2010 | Hitachi 55FX48B 55" Rear Projection...
50H13 Red Convergence Problem
I do wish people like troylove11 would stop giving advice on things they obviously know very little about. The Toshiba projection sets never have loose connections on the convergence IC's, and there are never bad resistors in those sets. There is no separate convergence board and there are no adjustments on any boards. The convergence adjustments are done electronically, through the remote in the service mode. Also, moving or bumping a projection set cannot cause a solder joint to crack loose. Your set has 2 large convergence IC's and one of them has burned out. This is very common in projection sets. Do not attempt to enter the service mode to make adjustments, because you will only be messing up the correct settings and when the new IC is installed, the colors will still be way out of alignment. Replacing a convergence IC is a very simple thing for an experienced tech, and it is well worth getting the set fixed. If your set uses the STK392-010 IC's, it is probably a good idea to go ahead and replace both IC's with the newer, upgraded STK392-150 IC's. If you have not changed the convergence settings, the picture will return to normal once the IC is replaced and very little realignment will be necessary. When I do a housecall for a set like that it takes about an hour and a half and I charge $150, but shops in your area will vary so ask around.
Sep 07, 2007 | Toshiba 50H13 50" Rear Projection...
Mdl kp53v85 red is out of alignment and bowed
Your convergence ICs are bad. They are about 20 pin chips located on the D board. They are on the largest heatsinks on the board. Check the resistors and fuses underneath or next to the heatsinks with an ohm meter to make sure all are good as they can fail with the ICs. This is a difficult repair but can be handled by a moderately skilled electronics tech. After all bad parts are replaced, run the magic focus to hopefully re-align the colors. If you have to go into service mode to re-align convergence data, the complexity of the repair just went up another notch. On a sony, service mode is tricky and a service manual would be highly recommended. Your tv uses two stk392-150 ICs (ic 1502 and ic 1505)
Dec 07, 2008 | Sony Televison & Video
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red horizonal convergence tilts instead of adjusting evenly.
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
147 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
