While playing a card game computer just quit and will not restart. Computer was connected to charger and battery showed full charge.
SOURCE: using battery charger with 3.42A vs 4.74A for lap top
check the amperage on the ACDC adapter block for both of them.
SOURCE: how to fit a new power jack (charger) in a acer
The first thing I suggest is to plug in your laptop then pull the cord under your laptop tug it towards you if you are able to obtain a connection use your laptop to hold the cord. Thats what I am doing now
If that does not work find the spot where you can connect ( by tugging cord back and forth or up and down) and hold the connection with tape or a clamp.
SOURCE: My Acer Aspire 5735z battery won't charge!
Your adapter port might have been improperly adjusted. Jiggle the cord around in there while it's plugged in to see if the plugged in light comes on. If it does then that's your problem. You can prob things under it to keep it at that point for a quick fix but I'd recommend a local computer shop for repairs.
-CompDoctor
SOURCE: My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi:
Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link:
http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
