Question about Lexmark X945E Printer
Failed to Create print object
I am trying to install from the original CD the needed drivers for my network printer and I get the following errors during the install process. I am trying to install on a IBM ThinkPad running XP sp2
Installation Error ---> Failed to create print object Lexmark X945E PS3 (Copy 1). The specified port is unknown (1796).
Step 1: Click Start --> Printer and Faxes --> Add a printer.
moz-screenshot.jpgStep 2: While wizard appear, click next and tick on A network printer or a printer attached to another computer. Click next.
Step 3: On the specify printer options, tick Connect to a printer to the Internet or on a home or office network. Specify your printer destination. Example: http://192.168.110.120/
Posted on Jan 30, 2009
Lexmark x5470 drivers won't install with cd or thru Lexmark on line. Using windows vista 32 bit.
Make sure to uninstall the old Lexmark driver before installing the downloaded driver. It should automatically create a print object under "Printers" after installing the driver.
Nov 24, 2012 | Lexmark X5470 All-In-One InkJet Printer
I keep getting the message failed to create print object Lexmark 6500 series. The specified module could not be found. (126)
It coudl be a printer driver issue. Please follow the steps below to fix the problem.
First, uninstall your existing print driver. On your computer, go to Start menu > Programs > Lexmark 6500 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
Second, visit the Lexmark website to download and re-install the Lexmark X6500 printer driver. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Lastly, after the re-install process, try to print again to verify that the problem is fixed.
Sep 06, 2011 | Lexmark X6570 InkJet Printer
Xerox 5500DN Phaser PCL driver installed and printer and IP recogized with web printing Prints setup and help info from printer panel pefectly Paralell or IP printing from PC Host only dumps hex output...
The printer is printing in hexadecimal the binary data it is getting over the network as it does not recognize the print stream correctly. Likely reason is that the print stream originator which would be a PC trying to print to it is using the wrong driver. Could try connecting the printer directly to the PC in question and installing it as a local printer then trying to print to it directly. If the result is still a hex dump, then the drivers are incorrect. Usually the drivers not only have to be the ones for the printer but also must be tailored for the PCs operating system as well. If you can get the correct drivers for the PC and can get it to print correctly on the Xerox, then the Xerox can be reconnected to the network and re-installed as a network printer (delete the old network printer first) on the PC. During the installation of the network printer on the PC, do a final test print to check.
Mar 18, 2011 | Xerox 5500/DT Laser Printer
Failed to create print object...The specified port is unknown (1796). I have uninstalled my printer and am trying to reinstall from the original install disk. I get nearly thru the entire process and...
To me it seems that the uninstallation proagram did not fully uninstall the printer. Can you first try this guide http://www.fixya.com/support/r5071075-windows_manual_printer_removal to make sure the printer is fully uninstalled. Once you have completed the guide, remove the printer from the computer and reboot it. Then try installing the printer and plug the printer in when the installation asks for it to be connected.
Jan 23, 2011 | Dell Office Equipment & Supplies
Can't reinstall my Lexmark printer
Usually, that can easily be resolved by uninstalling the printer completely, then reinstalling it. To uninstall properly, click on the Windows logo Start menu > Programs > Lexmark 6500 Series folder > Tools > Uninstall. Then restart pc. To reinstall, you can use the installation cd or if you don't have it or you lost it and since you have dial-up which is slow in terms of downloading, you can contact Lexmark Technical Support for assistance. They'll be able to send you one for free. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 12, 2010 | Lexmark X6570 InkJet Printer
How do I print wirless on a HP Officejet H470b
Hello my friend.First you must install the software if you haven't.Insert the Starter CD that was with your printer into the CD drive,the menu runs automatically,if its not double-click the Setup icon on the
Starter CD.On the menu, click the button for the connection method you want to use(wireless).Follow the onscreen instructions to complete the software installation.
After that we are going to create a wireless profile.
Open the configuration utility for your computer’s wireless network card, then do
the following:
Create a new wireless profile with the following values:
• Communication mode: ad hoc
• Network name (SSID): hpsetup
• Security (encryption): disabled
Activate the profile.
Wait two minutes for the device to obtain an IP address, then print a wireless
configuration page.
On the configuration page, verify the following for the device’s network settings:
• The IP address is not 0.0.0.0
Feb 08, 2010 | HP Officejet H470 InkJet Printer
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | Computers & Internet
It wont print
I don't know why it is, but, so many of the printer problems I answer have to do with original install cd being corrupted(it may have to with mass production process) anyway, you can try this:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 14, 2008 | Xerox WorkCentre XD102 Printer
Rimage Everest III printing quality issues
Hi Jay, do you have any idea how many discs have been printed with this Everest Printer?
Your issue sounds like a hardware error, not an issue with the software you are printing from. Most likely the printhead needs to be replaced, or the control board. Printhead replacement costs approx $1200.
- techware dist
Apr 14, 2008 | Rimage Everest Autoprinter Thermal
Lexmark X945E Printer Logo
4,071 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
