Question about iRiver Clix Digital Media Player
The screen is freezing
My pc is unable to identify my device from a week. its getting strucked. i tried using reset button. but its not helping. pls suggest me
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Touch screen frozen. Tried reset button ain the back. Completely charged. Was left in car for about 2 weeks (freezing temperatures).
turn off tuch screen get a hair dryer and blow in cracks of touch screen or the back you will have to find a way in to dry out moister from the cold.
Feb 27, 2011 | Garmin nuvi 650 GPS Receiver
Unit freezes at the loading maps stage
Yes! Yes! The exact same thing is happening to my nuvi 1300 right now one month after yours. What did you figure out? Can someone help? I've also tried to do the clear the device by pushing the right hand corner of the screen while powering on and I do not get any sort of 'would you like to clear everything?' message that I'm suppose to get. I'm going to check into battery recall that I heard about, but I don't think it's for the Nuvi 1300. Someone help! A :)
Jul 26, 2010 | Garmin GPS
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
Garmin 260W screen is blinking and beeping. Wont do anything else
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sure give it a try.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Aug 02, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Screen fading slowy and then reset
it is a software problem it seems like just hard reset ur device like this if it doesnt help then pls update ur System Rom from www.nokia.com
downlaod the software update utility from nokia and then connect the in ternet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do rsate me well if i helped u
Apr 13, 2009 | Nokia E61 Smartphone
N 78 Bluetooth unable to search new devices
Users have encountered a lot of issues, bugs and problems with Nokia N78, the first S60 device to support Feature Pack 2. If you are facing issues with your smartphone, here are a few tips to get your mobile phone back in business. + To restore your phone to the original factory default settings, press the Menu button, then go to Tools, Settings, General, Factory settings. Here you need to enter the lock code (generally 12345). After the reset, the device may take a longer time to power on.
+ To hard reset/format Nokia N78 (all data will be lost), follow the below mentioned steps:
1. Turn off the mobile phone.
2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these three buttons, press the power button to switch on the device.
4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
pls reset the device fully and if no help pls update the OS dont worry it is tested 100% may be in ur case the problem solves PLS RATE ME FIXYA if u like
Mar 16, 2009 | Nokia N78 Smartphone
Frozen on gogear screen
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 27, 2008 | Philips GOGEAR SA6045 MP3 Player
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
iRiver Clix Digital Media Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
