Question about eMachines W3611 PC Desktop
Volume has a mind of its own
My computer keeps turning its volume down on its own. I went to the system tray to see why I had no sound, and noticed that the bar was at the bottom. I moved it back to the top, and it slid back down on its own. Did the same thing in the larger window that you get when you double-click the icon in the system tray. :(
Oh, and if it's important, I'm running Windows XP.
  • a_dawning_cr Jan 30, 2009
    Thank you! It wasn't my keyboard, but I discovered that I'd set down my bookbag on top of my headset volume control.
Does your keyboard have a volume button on it that may be stuck down?
Posted on Jan 30, 2009
Can use pc speakers and plug them in the back to the earphones socket will it work
Yes. Keep in mind that the volume is adjusted on the computer. If you do not have a volume icon on the start bar, you need to click on start and type in Control Panel, click on the first Control Panel that appears. When the new window opens, click on Hardware and sound. Then look for Adjust sound volume, and click on it. Then adjust speaker sound and system sound.
Feb 09, 2016 | Computers & Internet
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Why won;t my volume shadow copy stay on or work?
VOLUME SHADOW COPY and sound functions have nothing in common other than both exist on a computer.
for volume icon, rt clk system tray expand button and select properties. Then turn volume on.
Sep 01, 2014 | Dell Latitude D610 P4 1.6 GHz CDRW/DVD...
How do i apply my volum icon to my computer
I am providing the solution by keeping in mind that the sound card driver for your computer has been installed and you want the volume icon to be placed in taskbar.
Please go to control panel -> Sounds and Audio devices -> Volume Tab. You will find the checkbox mentioning "Place volume icon in the taskbar". Check the box and click on apply.
You will be able to see the volume icon in taskbar.
Thanks,
Amar
Sep 14, 2011 | Microsoft Windows XP Professional
Dell Inspiron 1100 Laptop with FN Volume issues.
Starbug1S1- This may have been something you have already checked but I will suggest anyways. You said you had control of your sound from other means - Sounds and Audio Devices properties was one- did you notice a check box that reads Place volume icon on the task bar. This may remedy part of your problem if you put a check in the box. Hopefully this helps. Thanks.
Feb 11, 2010 | Dell Inspiron 1100 Notebook
Vista wont let my adjust my Volume
try restarting the computer, then go back to the Notification Area for your Taskbar, then verify if the volume icon is active for you to select.
otherwise, check this site
http://helpdeskgeek.com/windows-xp-tips/sound-or-volume-tray-icon-missing-in-windows-vista/
May 12, 2009 | Dell Inspiron 1525 Notebook
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
ACER ASPIRE 3000
Left click the volume icon in the system tray in windows.
A slider will appear which you can drag up and down to change the volume on the computer.
If the volume icon is not in the system tray, do this:
Go to Start->Control Panel
Pick Sounds and Audio Devices
Open the Volume tab
Tick "Place volume icon in taskbar"
Now you should have an icon in the taskbar.
If you cannot do this, then you do not have the proper sound card drivers installed and you computer will be playing no sound whatsoever, which is unrelated to your question.
Jan 25, 2008 | Acer Aspire 3680 Laptop
Vaio laptop volume problem
What version of windows are you runing? If it's pre xp it's probably nothing you are doing, windows's likes to corrupt itself over time. You can bypass your on keyboard volume by right clicking on the speaker icon in your system tray (lower right corner where your clock is) and click open audio properties, everything can be controlled in here. Good Luck
Sep 20, 2007 | Computers & Internet
eMachines W3611 PC Desktop Logo
103 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
