Here ya go. Here is a Repair Manual for you to Download. Let me know if you need more Help! Please Rate my Solution, I need all the Help that I can Get! Thanks!
http://www.eserviceinfo.com/download.php?fileid=33705
Just click this:
P {
MARGIN: 0px
UL {
MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px
OL {
http://www.wideformat.kodak.com/Support/Tech-Bulletins/files/NJ1000i%20Technical%20Bulletin%205_03072005.pdf
Regards:
Epson Stylus pro 4800 inkjet printer error codes and services. There are two types of error codes. Those indicating a maintenance issue that can usually be sorted out by resetting a counter or checking something is still OK after its nominal end of life. The second set are service errors that may need a technician to fix them, although many of them seem to respond to a certain amount of informed and sensible "fiddling" about; in some the descriptions indicate the action that should be taken to resolve the problem.:
Error Codes (Maintenance)
0002 Carriage Motor / Ink Tube end of life (Clear Carriage Motor Counter)
0004 Nozzle check error
0008 RTC error (Real Time Clock) (Check the Battery and reset the Date and Time)
0010 Multi Sensor Error
0020 Print Head life counter (Reset the Head counter)
0040 Cleaner Unit end of life (Clear the Cleaner counter)
0080 Date is not set (Set the date and time (RTC))
0100 RTC Battery low (Replace the battery, and reset the RTC)
0200 Paper feed roller life (over 75,000 sheets) (Reset the ASF counter)
Error Codes (Service)
00000088 RTC (Real Time Clock) data is corrupted
00000101 Carriage Motor life (Reset Carriage Motor Counter, check for leaky ink tubes)
00000103 RTC (Real Time Clock) battery is defective
00000105 Print Head end of life (Inspect print head and reset head counter)
00010000 Paper Feed Motor encoder check error (Check Sensor and Timing Disk)
00010001 Paper Feed Motor out of step
00010002 Paper Feed Motor overcurrent (Check for mechanical binding of the feed rollers / motor)
00010003 Paper Feed Motor in-position time-out
00010004 Carriage Motor encoder check error (Check sensor and Timing Disk)
00010005 Carriage Motor out of step
00010006 Carriage Motor overcurrent (Check for mechanical binding, If not replace motor)
00010007 Carriage Motor in-position time-out
00010008 Servo interrupt watchdog time-out
00010009 System interrupt watchdog time-out
0001000A Carriage home position error (Check Sensor and mechanical components)
0001000C Platen Gap home position error (Check Sensor and mechanical components)
0001000F Carriage Motor PWM output faulty
00010010 Paper Feed Motor PWM output faulty
0001001B Head driver (TG) temperature error
0001001D Carriage servo parameter error
0001001E Paper feed servo parameter error
00010020 CSIC read / write error
00010022 Ink type error
00010023 RTC (Real Time Clock) (Reset RTC)
00010025 CSIC ROM communication error
00010026 RTC (Real Time Clock) communication error
00010028 Head error
00010029 Unidentified NMI
0001002A Carriage ASIC ECU error
0001002B Paper feed ASIC ECU error
0001002D Cleaning Unit end of life
0001002F 360 DPI writing time out error
00010030 Multi Sensor failure (1. Check sensor, 2. calibrate sensor, 3. replace sensor)
00010031 ASF (Auto Sheet Feeder) home position error (Check Sensor and mechanical components)
00010032 ASF (Auto Sheet Feeder) Drive Switch error (Check Sensor and mechanical components)
00010033 Exit Roller home position error (Check Sensor and mechanical components)
00010034 Eject Roller lifted (Customer Safety Sensor on the eject roller)
00010035 Pump Home Position Error (Check Sensor and mechanical components)
00010036 Type B 1394 (Firewire) board installation (Remove Firewire Card / not allowed)
00010037 Print Head thermistor error
00010038 Head Driver thermistor error
00010039 PG adjustment value NVRAM error
0001003A PG adjustment value NVRAM error
0001003B Carriage Lock / Cutter Error
0001003C Carriage Lock / Cutter Error
0001003D Carriage Lock / Cutter Error
00020000 NVRAM error
00020002 SDRAM error
00020003 BOOT program SUM error
00020009 Flash memory SUM error
0002000A Program load error
0002000B Internal memory shortage error
0002000C Review error
100000E0 CPU address error (load misalignment)
10000100 CPU address error (storage misalignment)
10000180 CPU reserve command code exception error
100001A0 CPU slot illegal command exception error
100001C0 AC disruption (AC Power) (Unplug and wait 30 sec., then plug back in)
100005C0 CPU DMA address error
0003xxxxx –
0Dxxxxxxx CPU error
Hi hiro
The encoder strip is a black strip next to the rod that the ink cartridges run on and it spans the entire rod length. The following website link will tell you how to clean the strip. Please note that even though the brand is different, the technique is still the same for your printer.
Click Here For the Website
let me know if you need anything else.
Thank you for choosing Fixya
bestdarngood
If paper gets jammed try these steps ...and for the encoder strip open thetop cover and look behind the cartridge carrier there will be transparent plastic thin strip ,check if its loose or broken ,please do not break it or you may not be able use the printer ...check for any dirt clean it damp paper towel and repeat the process with dry paper towel ...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Service Request errors in the range 00010004 - 000101D are related to a
carriage movement problem. In some instances like paper jams, the
carriage locking tab may be partially pushed in, causing the carriage
locking mechanism to put a drag on the carriage or lock the carriage
completely. This will cause a carriage error. Make sure the carriage
locking tab is pulled to the left. Then turn the printer’s power off
and release the carriage by pushing down on the cutter blade. Slide the
carriage to the left and look for any paper that also may be
restricting the carriage from moving freely.
00010004
CR Motor encoder check error
00010005
CR Motor out of step
00010006
CR Motor over current
00010007
CR Motor in-position time-out
0001000A
CR axis detection error
0001000F
CR Motor PWM output faulty
0001001D
CR servo parameter error
The
T-Fence may also be dirty or out of the carriage encoder. Check to make
sure it is clean and in the center of the encoder. Contact Epson for
additional assistance.
The current firmware corrects erroneous Service Request 00010007, which occurs after the power is first turned on. You can download this firmware upgrade from www.prographics.epson.com.
Hi and welcome to FixYa,
Your posted error indicates that the carriage is jammed. This could be brought about by:
Opening the printer cover would give you access to the encoder strip.
Good luck and thank you for using FixYa.
An example of an encoder strip is shown below.
Based on here:
"In some instances like paper jams, the carriage locking tab may be
partially pushed in, causing the carriage locking mechanism to put a
drag on the carriage or lock the carriage completely. This will cause a
carriage error. Make sure the carriage locking tab is pulled to the
left. Then turn the printer’s power off and release the carriage by
pushing down on the cutter blade. Slide the carriage to the left and
look for any paper that also may be restricting the carriage from
moving freely."
Errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer’s power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
Good Luck
I still Have Error 001001E after i tryed checking
the print heads movement and it's OK. I also
tryed to look for any objects like jammed paper
but everthing works. I tried the roll paper but
after you bring paper to starting point, the
printer will not bring paper to the ready point
to print. also when it pushes paper from the tray
the paper gets jammed. I check for jammed paper
but printer is clean. Please HELP
I Can't find the encoder strip to clean. Please help!!!!!
