Question about Miele W2240 Front Load Washer
The washing machine wont start
I have been having this problem with my Miele washing machine where the two red lights start flashing. The check drain and check inlet lights. Is there anyway I can fix this myself?
  • 5 more comments
  • shamimehsan Jul 23, 2008
    I have a Miele W806 novo eco front load washing maching.The yellow LED light comes on but the machine program does not start. Also the door does not open. I tried checking if the drain is blocked which is mentioned in your other blog but the drain and everything there is clear. Please help!
  • Anonymous Mar 15, 2014
    inlet and drain lights flashing! have cleaned filter out at front of machine - still flashing - can I fix this myself
  • Anonymous Mar 16, 2014
    Miele the machine fills ten empties and inlet lights on
    The unit 4842 will shut off w/ a beeping error message about my water inlet drainage, or something to that effect.
  • Anonymous Mar 21, 2014
    Turn the it on and press the start button but it just frozen doesn't-do any thing at all the light still on we leave it on for awhile the start the light start plashing please help me solve our problem
  • Anonymous Mar 22, 2014
    Called out engineer who just attached it to his laptop said it needed a new circuit board and that would be $750!! Miele engineer too.
  • Anonymous Mar 23, 2014
    F50 fault displayed during wash
  • 183 Answers
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
SOURCE:
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Nov 16, 2008 | Miele W310 Front Load Washer
Miele W2240 Front Load Washer Logo
1,799 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
