Question about Hitachi 55HDM71 55 in. HD-Ready Plasma Television
Two lines in the screen vertical
The lines are about one and a half inches thick and run from north to south
  • Hitachi Master
  • 5,568 Answers
I don't know how integrated the driver circuitry is with the display but the screen is addressed like a matrix (XY) and some of the drive circuits for those areas have died. This could be an expensive problem; I hope you have some remaining or and extended warranty.
Posted on Jan 30, 2009
Is my tv water damaged or did it encounter some other type of assault that damaged it?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 26, 2015 | Vizio E-Series E550I-A0 55" LED TV...
Vertical line down the screen about 2 inches thick
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
Aug 06, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Thick Vertical Line
the power supply is defected a capacitor filter is leaking.have a tech repair your tv.good luck.
Mar 01, 2010 | HP PL5060N 50 in. Plasma HDTV
Solid vertical black line on my hitachi 42"plasma towards the left quarter of screen.bout an inch an a half thick.
This will be a block defect caused either by one of the flat flexible connectors to the screen giving a poor contact or a fault within the screen itself, which result in a replacement screen required
Sep 22, 2009 | Hitachi 42HDS69 42 in. Plasma Television
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Dec 21, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Hitachi 55HDM71 55 in. HD-Ready Plasma Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
