Question about Price Pfister 01-311 Shower Head, Tub Spout and Valve Set
Shower spout My Price Pfister pull handle on the shower spout to change the water discharging from the spout to the shower came out and I do not know how to fix it. I found a small white plastic with a rubber washer on it. I like to know how to put it back together or am I missing a part.
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Posted on Jan 30, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Tube and shower installation. Shower head dribbles water while filling tub. I used 1/2 copper and a shark tooth 1/2 copper to 1/2 FIp for my tub spout. I believe the fitting is restricting the flow t
It sounds like the diverter is not fully opening to allow the water to run to the spout. If the diverter is in the wall, perhaps there is a seal in there that needs replacing. If it is in the spout, just replace the spout,
Nov 24, 2014 | Price Pfister 8P8-PDKK Pasadena Single...
Help! When I pull out the control stem on the tub spout to send water through the shower head most of the water continues to flow out through the tub spout. Is there something that I can replace or...
You can replace the assembly and not have to worry about taking apart the stem or, you can get a replacement diverter. The spout will twist off turning counterclockwise.
Jun 14, 2011 | Price Pfister 01-111 Shower Head, Tub...
The shower tap is broken. The top came off of the plunger that changes the water flow from shower to tap and all the other pieces fell into the tub. Is there an easy way to fix it. I am definitely not a...
it may be very simple--you have to get your head underneath the tub spout and look to see if there is a "set screw" on it---if there is ,you unscrew it, which releases the screw holding the spout in place on the pipe coming out of the wall---jimmy it a bit and the spout will come off---don't yank too hard---if there is no set screw, then all you do is turn the whole tub-spout counterclockwise carefully, and unthread it from the pipe in the wall..replace w/ a new tub-spout--anywhere from $5 to $500
Feb 24, 2010 | Price Pfister 01-111 Shower Head, Tub...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
Sep 12, 2009 | Price Pfister Home
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Price Pfister 01-311 Shower Head, Tub Spout and Valve Set Logo
696 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
