Question about Ulead GIF Animator 5.0 for PC
Can't save gifs
Every time I try to save a .gif it says "Unable to finish GIF Optimization process" Will anyone please help me?
I had the same problem and googled a few forums with zero results.. so i found out what the problem was atleast for me... same error message when you try to save a GIF file "Unable to finish GIF Optimization process" What you need to do is this.
When you click on the Optimize tab you will get the same message again.. so click ok.. then at the very top second to the last icon is the Optimize Panel.. Click on it so the Optimize Panel comes up... then click on the Locate Palette tab.. and tic the "Preserve Local Palette" then you need to also tic the "Local Palette for all frames" once those two options are checked.. you will be able to save GIF files and the error goes away.. atleast for me this is what solved my problem..
Good Luck
Posted on Dec 08, 2009
  • 392 Answers
Reinstall your software
Posted on Feb 10, 2009
Looking for a 2.2 ecotec timing chain diagram with pictures
Getting the timing chain back on these engines can be tricky and requires more than just a diagram to get right. Here is how the timing chain should be reinstalled. Keep in mind that this engine can cause damage to the valves if the timing chain has any problems while the engine is running so it may not be a bad idea to setup the timing system as follows and do a compression test to make sure that everything is in order there.
Install the crankshaft sprocket with timing mark at the 5 o'clock position. Lower the timing chain through the opening in the top of the cylinder head. Carefully ensure that the chain goes around both sides of the cylinder block bosses (See 1 & 2 in picture):
Install the intake camshaft sprocket with the INT diamond at the 2 o'clock position. Hand tighten a NEW intake camshaft sprocket bolt. Route the timing chain around the crankshaft sprocket with the matching colored link aligning with the timing mark. Route the timing chain around the intake camshaft sprocket with the uniquely colored link (1) aligning with the INT diamond:
Install the timing chain tensioner guide through the opening in the top of the cylinder head. Tighten the timing chain tensioner guide bolt to 10 N·m (89 lb in):
Install the exhaust camshaft sprocket with the timing chain matching colored link (3) at EXH triangle aligned at the 10 o'clock position:
Ensure the timing marks and the colored links (1,2,3) are correctly aligned:
Use a 24 mm wrench to rotate the camshaft slightly, until exhaust sprocket aligns with the camshaft. Hand tighten the NEW exhaust camshaft sprocket bolt:
Install the fixed timing chain guide. Tighten the fixed timing chain bolts to 10 N·m (89 lb in):
Apply sealant, GM P/N 12378521 (Canadian P/N 88901148) compound to thread and install the timing chain guide bolt access hole plug. Tighten the chain guide plug to 90 N·m (66 lb ft):
Install the timing chain upper guide. Tighten the timing chain upper guide bolts to 10 N·m (89 lb in):
Inspect the timing chain tensioner. If the timing chain tensioner, O-ring seal, or washer is damaged, replace the timing chain tensioner. Measure the timing chain tensioner assembly from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 72 mm (2.83 in) (a) from end to end. A tensioner in the active state will measure 85 mm (3.35 in) (a) from end to end.
****If the timing chain tensioner is not in the compressed state, perform the following steps. Remove the piston assembly from the body of the timing chain tensioner by pulling it out. Set the J 45027-2 (2) into a vise. Install the notch end of the piston assembly into the J 45027-2 (2). Using the J 45027-1 (1), turn the ratchet cylinder into the piston:
Inspect the bore of the tensioner body for dirt, debris, and damage. If any damage appears, replace the tensioner. Clean dirt or debris out with a lint free cloth. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore. If the piston assembly is compressed against the bottom of the bore, it will activate the tensioner, which will then need to be reset again. At this point the tensioner should measure approximately 72 mm (2.83 in) (a) from end to end. If the tensioner does not read 72 mm (2.83 in) (a) from end to end repeat the steps required to return it to it's compressed state above.
Install the timing chain tensioner. Tighten the timing chain tensioner to 75 N·m (55 lb ft). Use a suitable tool with a rubber tip on the end. Feed the tool down through the camshaft drive chant to rest on the timing chain. Then give a sharp jolt diagonally downwards to release the tensioner:
Use a 24 mm wrench to hold the camshaft. Tighten the NEW camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees:
May 25, 2011 | 2002 Pontiac Grand Am
Batch convert image files, that keeps a folder tree?
If your not using version 2.20 then upgrade because there is no limit according to the manufacturer.
Dec 14, 2009 | Microsoft Windows XP Home Edition
Already have a lexmark x4270. can't recieve a fax?
Chances are you'll find your problem under 'fax settings' or a similarly titled option on the display. If you have it hooked up a computer as well you're in luck, most come with software that has an option labeled 'fax setup wizard' or something similar. Just follow the steps in that or call customer support at the following link to be walked through every step.
Lexmark Customer Support: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-332-4120cb_transparent_r.gif
Jun 26, 2009 | Office Equipment & Supplies
My son passed away two weeks ago and I'm trying to get his phone unlocked so I can maybe get some closure as to what was going on that could have led to his death. He was only 18. Teen mobile will not help...
I don't know if this will work. I just found it on this site. Good luck and sorry for your loss.
In order to hard reset the sidekick u have to take the battery cover off when it is off press and hold the {R} letter and take the battery out while still holding {R}, count 4 seconds and place the battery back into the phone while still holding {R}. If this was done right then right then you should see the phone restarting and when it is fully powered on then u should see that the phone lock is completely removed and the phone is not blocked at all
Mar 24, 2009 | Nokia N70 Cellular Phone
ASUS m2n32 won't allow me to go into setup; shuts down...
Try to reset your BIOS by removing the button cell located at your motherboard and put it back. Check the SATA connector of your hard drive and make sure it fits right. Boot the machine and set-up to "boot from CR-ROM". And install new WINDOWS XP.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Error (-48)
Error(-48) is somekind of hardware communication error. The easiest way to fix it will be to flash the firmware. Here's how to do it.. It will take a while(around half an hour) but its worth it and will also improve the sound clarity of your phone.
What u need :
1) Motorola Driver
2) RSD Lite or Flash&Backup 3
3) Monster Pack(Flash update for(Lseries including SLVR)
Firstly you need to backup all your files that stored on phone memory because it will delete everything in your phone when you flashing.
Start RSD Lite and let it connect to your phone. If your phone is not detected (and you are certain you have everything installed), disconnect the data cable, then shut your phone off, and manually put it into bootloader mode. You do this by pressing and holding down the "*" and "#" keys while pressing and holding down the on button until you see text display on your screen. Now connect the phone back to the data cable. Now click the button labeled "...".
This will bring up the open file dialog box. Find the file you want to use (in this case select your monster pack file) and then click the button labeled "Open".
Click the "Start" button. Now you should see various messages displayed on the screen as the program processes each code group and does various other things.
This is what the phone will display during a flash:
After it's finished and your phone has given you a confirmation tone, you can click "Close" and disconnect your phone from the cable and check out your changes.
If you should get a message like this where the program seems to hang:
Don't panic. Just close the program, chance are your phone is just fine. Sometimes this happens. This is usually caused by a checksum error. There could be more serious cases where you phone appears dead. In this case try to reflash your file again. You could also try reflashing another file.
Sep 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Sidekick i.d
report.gifTry this............................................................. 1. Get to the screen where you would normally type in the 3-digit privacy lock code
2.Hold key-menu.gif + key-jump.gif to get to the Emergency Phone Call screen
3. Hold key-jump.gif + + s which takes you to the SYSLOG screen
4. From there press key-done.gif, key-jump.gif, or key-cancel.gif and you're in!
Dec 06, 2007 | T-Mobile Sidekick ID Cellular Phone
Ulead GIF Animator 5.0 for PC Logo
1,512 people viewed this question
Top Ulead Computers & Internet Experts
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
