Question about Acer n30 Pocket PC
My n30 can't charge, but turns on under charging
I have an Acer n30, and now if I plug it on the charger, it turns on, the Battery Properties says it's on 01% (doesn't goes up after 4 days of charging) and when i remove it from the charger, it turns off and shuts down, and reinstalls. Can anybody help me?
  • 6 more comments
  • Timtayy Dec 04, 2007
    My acer n30 recently broke and i repaired it after a year or so. after fitting a new screen and a new battery it all works fine, but it will not charge and where the green light should be blinking a red light is in its place. will someone help me
  • Anonymous Dec 09, 2007
    same problem!
  • Anonymous Feb 26, 2008
    I have exatly the same problem. Can you help me what to do?
  • siedschlag1 Mar 09, 2008
    I have my n30 plugged in did the hard reset and still won't charge any other Ideas
  • Anonymous Mar 30, 2008
    My Acer n30 battery kept going flat even if it was switched off? It did this from day one but the battery is not covered under the terms of the warrenty! I purchased and fitted a new battery but it's exactly the same. I then charged the old battery (with another device) and it charges perefectly and holds a full charge, so the batteries themselves are not @ fault? I then monitored the n30's charge current (and there is none) the PDA makes no attempt to charge the battery even though the software says it's charging? I have tried all the reset suggestions all to no avail. The supplier has no answers, nor do Acer (as yet)?
  • martinblaodn Nov 26, 2008
    Hi i have the same problem but this doesn't seem to help any other ideas?
    Hi i have the same problem but this doesn't seem to work any ideas plaese thanks martin .
  • franzzz Dec 14, 2008
    i have some trouble here................
    but i don't know how to reset the pda...??????????????
    i have push buttons on the left, but it's only meke's off the scene and don't havereaction.............
    please help meeee
Hi, I had the same problem so i checked some other forums. I then found the answer. While your acer is plugged in, hard reset it, this switch is on the bottom of the machine. Switch the hard reset thing to the left for five secs, then back to the right. The green light should start flashing! You just fixed you acer!
Posted on Sep 01, 2007
If one hard reset doesn't solve the problem, keep trying until it does. You might want to wait longer before switch the hard reset thing back to right.
Posted on Mar 28, 2008
Power is plugged in , battery is plugged in not charging with 0% available
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
Acer aspire will not turn on or charge
Hello bperez28,
There are 3 possible reasons for that problem.
1. Battery is dead or is not seated properly. Try removing the battery from your laptop and then replace it back. If the battery is dead, it will not charge anymore. If it is still under warranty, ask for a replacement.
2. Charger is malfunctioning. Try to plug it into a different know working plug outlet. You might need to replace the charger with a new one.
3. Motherboard issue. Needs servicing.
You need trial and error to know exactly which of those is the reason why your Laptop is malfunctioning. Try a different charger/battery BEFORE buying one.
You can contact ACER directly from this link:
I hope this helped you out.
Thanks for using Fixya.
You can rate my answer if you appreciate the information I gave you.
Oct 06, 2011 | Acer Aspire 5100 Notebook
Hi There, My Acer N30 has completly frozen, it has
Hi, I think is software issue get someone to re-install the operating system of your ACER and it should work well again
Sep 22, 2017 | Acer n30 Bluetooth Pocket PC with BT GPS...
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Need new charger and battery and new pen
ebay is your best bet...
Try and on the search space, copy and paste on the following ebay Auction IDs (just paste the number I give you):
eBay Auction ID: 270215466248
1.5A Battery for Acer N30 N-30&Yakumo 1038006/PS1020#1
Approx. 7GBP = 13USD
Stylus (pack of 3):
eBay Auction ID: 280204418443
M509 3 pcs stylus touch pen for acer N30 N 30 PDA
Approx 1.5GBP = 3USD
Universal Travel Charger:
eBay Auction ID: 270216695513
Travel Charger for Acer N30 (UK/EU/US/OZ Charger)
Approx 7GBP = 13USD
These prices do not include shipping which may vary depending on your location... (these items usually ship from Hong Kong).
PS: these are auctions so the designated items may only be available for a limited number of days...
Hope this helps
Mar 03, 2008 | Acer n30 Pocket PC
Would u plz tel me wat to do
I looking for Charge Cable for Pc Pocket Acer n30-B
Dec 30, 2007 | Acer n30 Pocket PC
Acer n30 will not turn on
Trya hard reset, mine was off for 6+ months and wouldnt charge. After a couple of hard resets - bingo, fully charged battery.
Oct 31, 2007 | Acer n30 Pocket PC
Acer N30 battery problem (even new battery does not last enough)
try checking your power saving options, you can drop down the backlight a little lower to extend battery life. Also you can lower down the volume of the system sound and check if the bluetooth is on, then turn it off. Recharge it and then check if the battery life extends. You also need to occasionally soft-reset the n30
Oct 21, 2007 | Acer n30 Pocket PC
Acer n30 Pocket PC Logo
734 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
