Question about Ariens 34 In. Zoom Series Riding Mower
Airens Sno-Thro Model 926500 shear pin prolem
I purchased a new Airens last season -used it twice no problem. This season I have sheared 6 pins during the past two storms. Pins repleced on both sides of the auger???
Thanks
2 Suggested Answers
  • 183 Answers
SOURCE: Auger turning slow. Auger turns initially but
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
Posted on Dec 14, 2009
Why does the "shear pin" on the wheel axle keep shearing off?
Its suppost to do this to keep from damageing the transmission and gear reduction case on the unit
You must be hitting things while snowblowing that go beyond limit of the brakeing point of the pin .
Chunks of ice will case problems with smalled low powered mechines bigger ones to but it jambs them but the parts are bigger so the pins can be stronger .
Keep the same pins that are ment for mechine and use it carefully
Mar 23, 2015 | Garden
I have a Yamaha ys 626 snowblower - how do I fix a non moving auger?
Most snow blowers have a "shear pin", (or roll pin) that links the auger to the drive shaft. It is there in case you strike something hard with the auger. The shear pin will break and protect the auger, the engine, and the operator. The shear pin can be purchased anyplace that services snow blowers, and it can be replaced by the owner.
Jan 10, 2015 | Garden
Just bought a used cub cadet 528 see. Upon inspection noticed bolts not shear pins in the auger. Is this a problem?
The regular bolts may be a little stronger than shear pins. The previous owner may have had them shear off often so opted for the bolts to make them last longer. Get some of the original shear pins to get back the manufactures specs for safety.
Sep 24, 2014 | Garden
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to www.doityouself.com Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
Husqvarna shear pins break within minutes
if we are speaking about the shear pins on the tines, the ground is the problem and you need to begin your first pass on a more shallow setting and progress to a deeper setting gradually. if we are speaking about the shear pins on the tires w/o engaging the tines then these should not be breaking and I recommend that the tiller be examined by an authorized dealer.
Jun 15, 2012 | Husqvarna Garden
Broken shear pin in kitchenaid A9 Coffee Grinder
I was able to find 3/32 x 1/2 inch spring pins at a local hardware for 13 cents each. They may not last as long, but at the price I can replace as needed.
I also had to disassemble twice; I didn't notice that a portion of the old pin was wedged in the underside of the burr. When I put it back together the first time, the new pin rested on the old fragment and pressed the burrs too close together. On the coarsest possible setting, I got coffee powder!
Final note: The nut for the cap over the burrs is reverse-threaded...use a wrench on top, and a flat-blade screw driver in the slot at the bottom of the motor shaft.
Jan 01, 2009 | KitchenAid A-9 Electric Burr Grinder
Ariens 34 In. Zoom Series Riding Mower Logo
73 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
