How can i enable the sound of my computer? - Audio Players & Recorders
    Sergeant:
  • 219 Answers
Start>Control Panel>(Sounds, Speech, and Audio Devices>)Sounds and Multimedia (or Audio Devices)
In here go to Audio (tab at the top). On the sound playback device select, "Volume." Move the main audio playback slider up to increase the volume.
If for some reason there are no audio devices listed in the Sound control panel (unlikely), there is a possibility that your audio ports have been disabled (again, unlikely).
Go to your device manager by right-click My Computer (Either located in your start menu or on your desktop) and go to Properties. Now select, "Hardware." In here click the button, "Device Manager."
The device manager should appear. Look at, "Sound, video, and game controllers." If anything in this category is listed as disabled try enabling it, then exit the device manager.
Posted on Jan 30, 2009
The computer is not producing any sound from the speakers
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
Sep 02, 2011 | HP Compaq dc7600 Small Form Factor PC...
My computer says that there is No Audio Output Device installed
Go to Control panel -->sound device ---> check the sound device is getting enable (or) not. If not enable the sound drivers is not install properly, at the same time check the BIOS setting sound device is enable or not...
Nov 13, 2010 | E-Machines eMachines Desktop PC
I plugged my speakers into the orange circle behind my computer, and no sound is coming out. Why isn't working?
Hello Shantilla hi, the orange port is for the Center speaker for a 5.1 surround set up. to enable this you need to find the controls of the sound setup. usually on the lower right side of the computer. If the sound card is a Realtek brand the sound manager is the orange speaker ICON, need to open this sound manager software and enable 5.1 surround. You need the SOUND driver to use the surround setup.
Sep 21, 2010 | Polk Audio RM6700 White 5 Piece Satellite...
After re-enabling my computer speakers, when music is played out, the sound is very jumpy. Such as, i put a song on and only a second of noise will be played and again every now and then. The speakers are...
Go to my computer, right click on icon, go to properties then select device drivers. disable the sound and audio device. restart the pc. then again go to the my computer, right click on icon, go to properties then select device drivers. now enable the sound and audio device reinstall the drivers,it should work
Sep 04, 2010 | Logitech X-240 Computer Speakers
Disabled speakers. Want to enable them. How?
1. If you mean speaker being mute, get in to control panel and sound and audio device.
2. If you mean the sound adapter is being disabled, go to control panel choose system. choose hardware and go to device manager. look for your audio adapter, right click and choose enable.
Oct 05, 2009 | Acer 90.00012.30B Computer Speakers
No sound on computer
check your sound cables speaker power button and speaker icon on computer is it enabled some dell pc have sound option in biose which needs to be enabled
Jul 22, 2009 | ViewSonic VA721 17" LCD Monitor
NO SOUND AT ALL
First check if the onboard sound is enable on your computer's BIOS, so restart your pc and press the DEL key on your keboard so you can access it then make sure the audio is enable if its disbale enable it then try now if it will working.
If the audio is enable on BIOS and still no sound check if the audio is installed properly under device manager Right click on Mycomputer>properties>hardware>device manager>then look for the audio device that should be enable and working properly if not you need to reinstall the driver for it.
Jun 06, 2008 | Gateway 500GR PC Desktop
No Sound
did you install anything before this problem started? if yes try to uninstall it. if not, check device manager if your sound card drivers is still installed and if it is enabled. to go to device manager right-click Computer then click Manage. look for device manager then sound.
if it's enabled and there are no problems to the sound card go to control panel then Hardware and Sound. click on sound then check if the default digital output device is selected and enabled.
if it still won't work last option is do a system restore. set the restore date before the time the problem happens.
May 27, 2008 | Gateway GM5620 PC Desktop
No sound from Emachine computer
Pathannan
You have to disconnect your cables again and put it in the green conector. then start up your PC, and check the mixer con sound multimedia if all is up, and NOT MUTE, then see if sound is comming again, check if your sound card, is ENABLE on BIOS, and drivers are ok.
Good Luck
Dec 30, 2007 | Audio Players & Recorders
HP Pavilion A1120N
Verify the sound device is enabled If there is no sound from the speakers or headset, use the Device Manager to determine the state of the sound hardware.
  1. Click Start , type manager into the search field, and select Device Manager . Alternately, click Start , Control Panel , Hardware and Sound , and then Device Manager .
  2. Double-click Sound, video and game controllers .
  3. Do the following, depending on what is seen:
    • If a sound device is listed with a down arrow , the device is disabled. Right-click the sound device name and select Enable to re-enable the device. Go to the next step if problems continue after enabling the device.
    • If a sound device is listed and enabled , right-click the device name and select Properties to view more helpful troubleshooting information in the Device Status window. If Device Status shows that the device is working properly, the problem is likely related to sound settings, the speakers, or the audio cables and connections.
Dec 25, 2007 | HP Pavilion DV4015cl Notebook
61 people viewed this question
 Grubhead
Grubhead
