Question about Zenith ZHX-313 System
I need help
How do i get this thing off of progressive scan mode so i can view my movies again and how do i set the radio stations without the original remote?
  • laurie corona
    laurie corona Jul 29, 2007
    thank you very much you were most helpful
    President:
  • 1,114 Answers
From the manual (link below)... "Once the setting for progressive scan output is entered, an image will only be visible on a progressive scan compatible TV or monitor. If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that ?NO DISC? is displayed on the display window. 2) Press STOP and hold it for five seconds before releasing it. The video output will be restored to the standard setting and a picture will once again be visible on a conventional analog TV or monitor." http://136.166.4.200/contents/files/STB/ZHX-313/ZHX-313_Owners_Manual.pdf Radio operation is on page 39 of the manual.
Posted on Jul 28, 2007
SOURCE:
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
I pushed the pscaan button by mistake n now I can hear the movie but no picture
This is probably the 'progressive scan' feature for your DVD player.
If you haven't had any other problems with the player, try pushing the button again (a second time). This feature is likely a 'toggle-on, toggle-off, so a second 'push' should turn-off the progressive scan.
If this doesn't correct it, power the unit off, then power-on again. It it doesn't automatically power-up without the progressive scan, try pushing the pscan button again. Hopefully this will turn-off your undesired progressive scan. Good luck!
Feb 05, 2011 | Oritron DVD600 DVD Player
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
hi,
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
ok
Jan 13, 2011 | Zenith XBS444 System
Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Jan 29, 2008 | Zenith XBS344 System
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
be restored to the standard setting, and a picture will once
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
Progressive Scan
SOLUTION #1
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
Zenith ZHX-313 System Logo
206 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
