Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Nothing is happening
The CLEANING light blinks, but nothing happens. I loaded it Sunday, set it for 2 hour delay, and didn't even notice that nothing has happened. I have cancelled the print, opened, closed, even reset the breaker - what's up?
I used the eternal last resort: Banging repeatedly on the control panel!
Posted on Jan 31, 2009
I hit the delay button for 2 hours yesterday on my kenmore elite front loading washing machine and nothing has happened and the door is locked
unplug it and wait for the machine to reset. You should hear some clicking noises. May take a while for it to reset.
Jun 28, 2014 | Kenmore Elite HE5t Washer
Dell 1525 Stuck at DELL Screen
The bios is working fine its the little program that runs the system like run the setup, entering set up is not running because the file are not there you need to use and run setup from a cd
Apr 23, 2017 | Dell Inspiron 1525 Laptop Jet Black
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
Put the key in the ignition and nothing happens (the dash all lights up windows work) but not even a click , happened once this morning and we rocked the car and it was fine has started 2-3 times since and...
Sounds like either bad battery or really dirty battery cables. Have you tried jump starting? I'd first start with cleaning battery cables top & BOTTOMS. Everyone cleans top because they're easily accessible, but the bottoms are exposed to dirt & road grime and are usually the culprit. After cleaning cables, if problem exists then replace battery. You can verify battery by having any good parts store "load test" battery.
Mar 22, 2011 | 1994 Nissan 240SX
Dishwasher lights up when Normal Wash is pushed, also heat dry - but when start is pushed all three lights (Normal wash, heat dry and washing) blink then go out and nothing happens. This occurred after a 2...
What is the make and model so we can better assist you? In the mean time shut power off to the unit briefly, then turn it back on and try a normal cycle. Will be watching for a make and model here.
Jan 20, 2010 | Dishwashers
The clean lite came on, I held down for numerous seconds & it blinks, but nothing happens--I have tried unplugging &hitting the on button--nothing seems to make the cleaner vinegar go thru the...
The cleaning cycle takes about an hour. Unplugging, or turning off only delays the process. Place your solution in and set the self-clean, then walk away for about an hour. If it has not completed after an hour, call the GE service numbers found on the front of your user's manual.
Jan 04, 2010 | GE 106591 Coffee Maker
My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
Dec 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
137 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
