Question about Dell 3100cn Laser Printer
Dell 3100cn Duplex won't feed
The 1yr old Dell 3100cn I have suddenly will not feed through the duplex mod. When ever I try to print two-sided documents, the paper feeds through the regular paper path. Only the first page comes out then I get a 077-105 Error "Paper Jam Fuser". Of course, there's no paper jam. This error message flashes with "Open Duplex Mod Remove Paper." Again there's no paper. I've pulled off the duplex mod and set every thing back to the original state. Then I reinstalled the duplex mod, but the problem remains. Any ideas on why the duplex mod no longer feeds paper? Thanks!
  • 5 more comments
  • Anonymous Feb 13, 2008
    My Dell 3110cn wont print duplex either - nothing happens.
    The same printer I have will not print duplex either
  • tjjarusab Oct 24, 2008
    I have a similar problem where I get "Paper Jam" error with the instruction to "Open Duplex Mod". I've only printed 5500 pages, barely enough to get through one complete set of toner. The problem occurs once every month or two and somehow self corrects after opening and closing every latch on the printer. And of course, there is no paper jam. Dell's tech support didn't resolve the problem. As an IT professional, I'm disgusted and not happy with Dell. For the $700 that I paid for this printer, I've had more trouble than any other printer. I'm inclined to never buy Dell printers again. Very disappointed.
  • Anonymous Mar 14, 2014
    dell 2155cdn paper feed error
  • Anonymous Mar 25, 2014
    when using a heavier paper, the duplexer doesn't allow for two sided printing...how do I fix this?
  • Anonymous Mar 26, 2014
    jamming duplex
  • Anonymous Mar 27, 2014
    I have checked all the paper paths & have not found any paper jam. I've cleaned everything I have access to. I've tried removing the toners & cleaned them too. The paper jam error message will not go away. Please help.
DO NOT BUY DELL 3115cn color laser printers-will not duplex printer and Dell has no record of my purchase so refuse to help me plus their online manual will not come online. Purchase from Hell. Their records show my printer is in their warehouse even though it is in my living room.
Posted on Nov 07, 2008
  • 28 Answers
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Posted on Jul 28, 2007
SOURCE:
Getting an error message 016-799
One reason this error message is displayed on Dell laser printers ... attempting to duplex print using the Single Sheet Feeder (SSF). Try printing document single sided if using the SSF.
Mar 15, 2014 | Dell 3100cn Laser Printer
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 01, 2011 | HP LaserJet P4015N Printer
Dell 3100cn Laser Printer - Not capable of duplex printing? Or yes?
Hi. Duplex printing is optional. You need to purchase additional accessories to enable duplex printing.
Aug 19, 2010 | Dell 3100cn Laser Printer
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
How do you print on both sides of a sheet of paper
Unless you are using a duplex "Multifunctional" copier(with fax.) most plain fax. machines are not duplex and will only print on one side of the page.
If you have a machine capable of rx duplex printing please specify make and model for additional help.
Mar 22, 2010 | Office Equipment & Supplies
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
I need to know how to choose a duplex print option for this printer.
when choosing the printer go to printing preferences and you will see the option for duplex if the printer has that option.
Apr 30, 2009 | Office Equipment & Supplies
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Duplex printing won't work
There is no duplex on this printer, two sided printing is only achieved via manual feeding, I checked the canon website spec for the MP460
Oct 09, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Dell 3100cn Laser Printer Logo
1,257 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
