Question about SMC Computers & Internet
My SMC7904WBRA2 router says its connected to the internet, but there is no actual access? why is this?
We've just bought a SMC7904WBRA2 network router. When its wired in (LAN1) it says that it has internet access, but none of our laptops will connect to the web. Also, if its connected an on my laptop is picking up the signal and constantly searches, which slows down all other programs. Can anyone help?
    Master:
  • 545 Answers
Call your ISP and have them approve the new device.
Posted on Jan 03, 2018
Benimur
  • 6966 Answers
SOURCE: Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Posted on Feb 10, 2008
One Piece
  • 53 Answers
SOURCE: connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Posted on Apr 14, 2008
jeicrash
  • 320 Answers
SOURCE: please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Posted on Jul 21, 2008
SOURCE: bad connection. dropped internet when connected with mac wired or wireless
I'm not sure but it could be that the particular router has some hardware issues. I bought a Belkin wireless N router a few months back and i had the same problem. It only had a short range and kept cutting off in between. I exchanged it with a new router and voila!. it works fine.
And the other thing i've come to notice. At times having the router under the desk or at a corner might not give off enough to provide a connection within the adjacent room so I've had to place the router in a open and unobstructed place. So much for belkins super signalling.
Posted on Jul 08, 2009
  • 226 Answers
SOURCE: Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Posted on Jul 20, 2009
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I got the network but cannot connect to the internet
Check to see that the network is actually getting data. If no other machine can connect to the internet through the same network, then it's a problem at the router or the source.
If other machines can connect, cut your wifi off and on again, and try again. If you've been on this network before, but now can't get anything, you might need to delete the profile for the network and re-create it -- network profiles corrupt from time to time.
Nov 11, 2012 | Toshiba Satellite L455DS5976 Notebook
Can't configure the network with ethernet cable
Hey, you're almost there. The connection between the no-wireless PC over ethernet to the DAP-1360 Repeater is fine. The reason it can't connect to your LAN or the internet, however, is that the repeater isn't actually repeating your Ofir network, it is instead creating it's own, completely isolated wireless network (Ofir_EXT).
The D-Link setup and documentation is confusing, and doesn't have proper instructions for the repeater setup.
Rerun the setup wizard, setup as a repeater, then select manual configuration method.
Now, enter the wireless network name of your the network you want to extend (in this case, Ofir). Then enter the same security and password etc. for Ofir in the following fields, just like you were connecting to Ofir from a smartphone or laptop.
Once that is finished, you should be up and running. If things worked, you should NOT see any new wireless network. There should be Ofir and just Ofir. Wireless repeaters work invisibly, you'll still connect to the same network like you always did, but now it will have much improved range thanks to the DAP-1360. The computer entherneted to it should be networked on the wireless LAN and have internet access after this as well.
Good luck, I hope my instructions were clear. Wifi networking is easy, it's understanding all the manufacturers less-than-intuitive software that makes it hard.
Oct 16, 2012 | D-LINK SYSTEMS DAP-1360 Wireless N Range...
I can't connect to the internet wirelessly. i don't think my linksys router is working
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 29, 2012 | Linksys Computers & Internet
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
My wireless is not connecting to my computer its saying UNIDENTIFIED NETWORK ACCESS LIMITED CONNECTIVITY
You may be connected to the router, but the router may not be properly connected to the internet. You could try unplugging the router's power for 15 seconds, then plugging power back in. Also, try making sure all the cables in the back of the router are plugged in properly. The last thing you could try is restarting your actual modem. This is the device that actually connects to the internet, and it sounds like you're having internet connectivity issues. So the problem may be there.
Sep 12, 2011 | NetGear WGR614 Wireless Router
I was setting my configuration for my wireless modem to my internet modem using my disc I keyed in a wrong username and password how can I change it to the correct one please?
You can access the router through web interface and configure it. All you have to do is connect the router. Follow the steps given below: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 (written at the back of router) depending upon the make/ model of your router
(unless you've configured otherwise, the default username is admin and the password admin OR password.) and lookup for the security options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Also make the following changes (recommended): -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password admin OR password.)
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Feel free to contact me for further assistance
CreativeTECH
Aug 05, 2011 | Computers & Internet
Hello, I've had my D-Link router for about 5 years now. The model is WBR-1310. The connection worked fine up until today. I took off the connectivity between the router and my PC about 6 months ago,...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | D-Link 802.11g Wireless Router WBR-1310...
For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
Jul 29, 2007 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Computers & Internet Logo
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
