Question about HP OfficeJet G85 All-In-One InkJet Printer
My office jet g85 occasionally fails to print a web page
The only solution i have found is to reboot the pc. this requires much time and causes much frustration. is there a simpler solution?
    President:
  • 2,692 Answers
Reinstall the software and driver.   Seems that you have a software glitch.
http://h10025.www1.hp.com/ewfrf/wc/product?product=60399&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Jan 30, 2009
G85 desk office jet
According to Intuit it may due to inappropriate printer driver settings, for resolve this issue follow these tutorial steps Problem Printing Transactions to HP Printer and if not have enough technical knowledge or need any guidance during this process follow Intuit Support Number .
Feb 01, 2014 | Intuit Computers & Internet
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
My office jet G85 has the message "remove and check color
Check and make sure you drivers are up to date. You may need to un-install the printer software and remove the printer in the control panel. Then reboot the computer,install the software(check and see if there is updated software if so download it).Then install the software and usually gives you instructions on when to connect the printer and drivers should be installed by software. Also make sure that when you use the print screen that you have the default printer selected and that the office jet is the default printer. It may be set to print to Microsoft one note for example.
Sep 05, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Just got a new hard drive on my Apple Power Book G4 using Mac OSX 10.4.11   Now when I use my Office Jet G85 to print I get the job set up, hit print, and everything appears to be right but the job...
Since you're on a Mac you have access to a great tool called CUPS. If you point your browser to http://localhost:631/printers you will notice a list of active printers. If there isn't a printer listed you must reinstall your Office Jet (all the software can be found here), but if the Office Jet is listed there are many tools that will help you fix your printer. If you are prompted for a user name and password within CUPS just enter the User and Pass that you use to login to your Mac.
Good Luck
Jordan
(suprherogeek)
Jan 14, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
The screen on FeskJet g85 says that cartrdge alignment has failed
Here is the link below which helps you in resolving the issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60399
Click on the link above to open web page and follow all the steps given in document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Office jet g85
Power on the printer, wait around 15 seconds until the bulb assembly moves a bit to the left and the light goes on, then immediately power off.
Repeat the process around 15 times (or more) until the assembly has moved all the way to the left of the glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using a dry Q-tip, carefully insert it into the slot (to the left of the bulb) and clean the mirror. I found mine was coated with a layer of film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
Dec 17, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
Ben Johnson
