Question about Reddy R60A Utility Heater
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
I have a Reddy Heater 50'000 BTU Kerosene Heater. This is the white unit with maroon stripe, with the handle on the top.
When I plug it in unit just puffs smoke 3 or 4 times and tries to burn but then just shuts itself off. If I hit the reset switch, it just does the same thing.
What gives?
Thanks,
Bob
  • musicman1116 Jan 30, 2009
    P.S.
    The unit is also leaking a little Kerosene out the front end as well.
    Thanks,
    Bob
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Puffs smoke when starting
You may have contaminted fuel, a dirty nozzel, or you may need to replace the fuels. Insufficient air flow also can cause this. You can go the manufacturers webite a www.desatech.com . They offer service manuals that should be able to assist you. Thank you
Jan 27, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Jan 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
70,000 BTU Reddy heater - runs - but it puffs smoke
heatman101
Dec 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater R35A problem
clean all the spiders out and then throw it away the fuel tank is not designed to sit,rust will kill you personally being onfire is not fun. problems like this is common. main problem is moisture or rust could be a rat living in it.
Jan 03, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy R60A Utility Heater Logo
1,306 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
