Question about Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White
Whirlpool duet electric dryer - drum turns; no heat
Our Whirlpool duet electric dryer, drum turns continually when door is shut - no lights on display but no heat.
  • 6 more comments
  • Anonymous May 03, 2009
    Drum turns but just cold air
  • Anonymous Mar 14, 2014
    my dryer will not turn off
  • Anonymous Mar 17, 2014
    le8860xwq0
  • Anonymous Mar 18, 2014
    Whirlpool Duet dryer makes noises when operating
    Dryer drum makes noise when running.
  • Anonymous Mar 29, 2014
    My samsung electric dryer reads de drum light
  • Anonymous Mar 30, 2014
    My samsung electric dryer reads drum light
    Have cleaned out heat exchanger and no heat in drum. All lights working and switching off
  • 150 Answers
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
If the dryer inside light comes on can the thermal fuse ok
No relations at all......
Light comes on means there is power and your door is open.
Thermal fuse failure means there is no heat. No current going through your heating circuit. Most models and brands will still turn the drum without heat. But there are some models thermal fuse will completely shut the power to heating circuit and drum motor. Like KENMORE certain dryers made by Whirlpool corporation
Jul 22, 2014 | GE GTDP180EDWW Electric Dryers
Whirlpool duet dryer won't heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Jul 02, 2014 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryer shuts off after one minute
  1. Lid Switch Doesn't Latch
    • A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
    Unsteady or Damaged Power Cord
    • A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
    Triggered Thermal Fuse Faulty Control Panel
    • The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
Dec 11, 2013 | Dryers
Whirlpool Duet WED9150WW dryer heats up but does not spin. The belt is not broken and door switch appears to be working.
If the dryer is on and everything is working except the drum is not turning, then the motor is bad. Here is the new motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Logo
2,329 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
