Question about Kodak EasyShare Thermal Photo Printer
How to clean photo jam at my kodak all in one printer 5300 aio ?
Paper got stuck, then i don't know how to put out the paper..it just kept stuck in the printer...is there anyway i can make it work? i am using kodak 5300 AIO
thx
    Scholar:
  • 60 Answers
If there is a paper jam then open the rear access door and look for any paper or piece of paper stuck in there if not then try and roll the roller slowly to check for paper jam........if you still cannot find the paper then open the front access door as if you are trying to replace the ink cartridges and look inside if you can see any paper stuck in there or not........if still no paper restart the printer after 30 seconds and check if still getting paper jam or not............if yes then contact Kodak tech support.......
Posted on Jul 17, 2009
Kodak 5300 AIO Paper Jam
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 AiO Printer will not work due to paper jam
Looks like the sensor for paper jam is causing you problems.
Worst thing is that Kodak discontinued the whole 5xxx series because of all the problems those printers had.
I don't know if you will be able to fix the problem through Kodak support, I guess you will have to give them a call.
Good luck,
Milan
May 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 paper jam
What kind of paper is jamming?
The paper could be too thin, or too thick.
Have any young children visited you recently?
My neighbour's grandson thought the paper tray was a great place to hide his Oreo cookie and gummy bears. The crumbs on the roller made the paper wrap around inside. It was cheaper to buy a new printer than pay for a tear down. This happened to my neighbour over Christmas.
Check for spilled ink inside the cartridge area.
If Ink has dripped down on the rollers, that would jam the paper. This would only be an issue if anyone moved the printer. Could your cleaning person have done this? It happend to me, once.
Have you checked the slider that adjusts for different paper sizes?
It could be putting too much tension on the paper and throwing off the timing of the paper travelling through the printer, so the sheet is in the wrong place at the wrong time and jams up.
Is it 8.5" x 11" photo grade inkjet paper or 4" x 6" photo paper?
Before I print, I check that the paper type setting matches what is in the tray. If it is letter size premium photo paper, then I choose that paper in the printer settings. If it is premium letter size paper for documents then I choose that paper, so the printer can adjust itself to the paper.
Are you using recycled paper?
My Kodak, HP, Epson, and Canon printers jam. Recycled paper really screws up my machines. I don't like it and can't use it.
Do you have too much paper in the tray?
Try 5 or 10 sheets only in the tray to see if the amount of paper was the culprit.
Have you tried a different package or brand of paper?
One time a package of 500 sheets of HP inkjet wouldn't go through my KODAK , but worked fine in
the other printers. The next package of HP paper worked fine.
How long has the paper been out of the package and sitting in the printer?
Try fanning the paper.
Has the humidity in your area drastically changed in the past week?
I have to keep the paper sealed in the original package. Inkjet paper out of the package is affected by humidity where I live. Winter heating causes out of package paper to collect static and stick to the rollers. Summer temperatures with high humidity causes out of package inkjet paper to absorb moisture from the room. This humid paper sticks together.
Is the paper meant for a photo copier or laser printer/copier?
I get lousy results with non-inkjet paper in every brand of injet printer I use.
Is it Brand name InkJet paper, like Kodak, XEROX, or HP?
I stick to brand name inkjet and photo paper. Dollar store paper always jams in my printers.
For Document Printing I use either:
Kodak's 24 lb Ultimate Inket Printer Brightness 98 paper,
XEROX Premium Inkjet Brightness 98 24 lb,
or
HP 96 Brightness Premium Inkjet Printer 24 lb paper.
For Photo Printing I use Kodak's Ultra Premium Photo Paper, and adjust the printer's settings for it.
Jan 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam
Paper jam means that the rotation of the roller is not smooth, either because you are not inserting the paper correctly or there is something stuck in the printer. What you have to do is open the back cover of the printer and check the roller and clean it. Then if still paper jam is there, then it's manufacturing problem. Contact manufacturers.
Dec 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
NO user manual for new 5300 printer!!!!
If you want to switch to photo mode you have to have photo paper in the printer. As for the user manual you did get one, just not in paper form. Kodak has the user manual on the software CD or you can go to kodak.com. The reason it's not in paper form is because the user manual is more than 100 pages.
Oct 31, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 Series not a year old
try to do this first, try first to upgrade the firmware of your printer, by clicking help in your kodak AIO Home Center, then under General Links, click on maintenance, then under maintenance, click on firmware upgrade.
after the upgrade is complete, try to remove and then reseat both the ink cartridges. then calibrate your printer. and then clean the printhead deep clean. then print a demo page to see if there is any improvement in your printout.
but if your still experiencing the same problem
you can call to Technical Support of kodak 1-800-421-6699 7am to 12am ET
hope this will help
Sep 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink pooling on phot paper
1-Deep clean and calibrate the printhead
2-Try a firmware update @ www.kodak.com/go/downloads
3-Try a removal and reinstall of the printhead and inks
If all this fails, call Kodak Aio support : 1-800-421-6699 (USA)
Jun 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
My 5300 does´t print yellow my photo as a lot o red
Unlatch the printhead by pressing the button in the upper-left corner of the carriage.
see User’s Guide page 75
you can see it at www.kodak.com/go/downloads
I would also advised you to do a deep clean by going to menu>clean printhead then deep clean.
Believe this has nothing to do with cartridges
contact aio support if this fails
Apr 07, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare Thermal Photo Printer Logo
270 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
