Question about iRiver Clix Digital Media Player
Iriver clix , the same Device is not working !
The same divice isn't working , i can't turn it on !
SOURCE:
SOURCE: IRiver Clix will not power on
I had the same problem, the player initially froze when switched on, then it was unrecognised by windows XP, finally the player would not power on or respond. It was returned to iriver europe and the motherboard was replaced. Works again! Very good service from iriver.
http://www.iriver.eu.com/rma.html
Posted on Dec 21, 2007
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Posted on Jan 25, 2008
SOURCE: iriver clix2
If you have a song up just click and hold to the right and a bunch of options should show up. The first option should be "play mode" and in there you can choose whether your playlist (or album, depending on how to navigated to the song) will shuffle and repeat.
Posted on Feb 29, 2008
SOURCE: Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Posted on Mar 06, 2008
SOURCE: how to open iRiver clix 1
Go through this link. Hope it will help u.
http://www.anythingbutipod.com/archives/2006/06/how-to-disassemble-the-iriver-clix-u10.php
Regards,
Satish
Posted on Mar 17, 2008
I tried to format the iriver clix 2GB but now in setting i can see 0MByte .. Where is the memory gone :( I cannot copy anything as it is giving no available memory
if you just formatted (you deleted everything)...........for future references when formatting you must save the device software to a flash / hard drive. This is what makes the device tick.... IF by chance you know anybody with this device other than you, you can copy their software......... (Iriver global only have firmware)...... and the only other suggestion is to use it as a external hard drive..... :(
Jan 22, 2011 | iRiver Clix Digital Media Player
Iriver clix gets static-y after a few minutes
Hello Cart, I am sorry to hear that your Iriver Clix Gen 2 4 gb video player recieves enormous amounts of static that makes it unaudible after a couple minutes. I see that you have eliminated one of the factors of static by upgrading the firmware, but unfortunately the firmware is only related to booting up, and loading your movies/music. If the static is coming from the speakers, you may not be able to fix it, unless you open up your Iriver Clix, which I recommend you not do, due to that it will void your warranty. The Static may be caused due to excessive geforce or impact to your device, causing the wire's to be loose. If the static is coming from the speakers, I would recommend you to return it to the manufactuer or return it back to the store. If the static is coming from the 3.5 mm plug, try a different pair of headphones or earbuds, make sure it is fully plugged in, I would also recommend you to return back to the manufacturer, or return it back to the store. -Tom Smith.
Aug 26, 2007 | iRiver Clix Digital Media Player
Formatting
You should try to upload the newest firmware for your device. Simply go to irivers site, look under Iriver Clix Generation 1 support (I'm guessing you have the generation one... if not, just click generation two). Simple as that!
Sep 21, 2008 | iRiver Clix Digital Media Player
Iriver clix - dowloading music from laptop to iriver clix
If you set up Windows Media Player to autosync to the Clix, then, when you delete songs from the computer (including the wallpaper jpeg), the files also get deleted off the clix. Make sure you have Manual Sync enabled in Windows Media Player (or, more accurately, disable auto-sync).
If auto-sync is already disabled, then you have a good, old-fashioned DB corruption. You can reload the firmware from iRiver's website:
http://iriverinc.com/support/ultra/clix2.aspx.
Sep 07, 2008 | iRiver clix 2nd generation MP3 Player
Don/t work for any click
To force PC to recognize, hold in one of the buttons on the side of the Clix while connecting the clix to the PC - should force recognition in 10-15 seconds.
Mar 01, 2008 | iRiver clix 2nd generation MP3 Player
Iriver MP3 player
the same thing happened to my iriver it means something you have downloaded had a virus and you need to have the device serviced
Sep 25, 2007 | iRiver Clix Digital Media Player
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Iriver Clix (Gen1)
i lost the driver of my iriver clix gen1 2gb please send the driver on my email address thanx my email is [email protected]
battery. if you are charging it and it won't hold the charge perhaps you just need another battery. the worst thing it could be is the motherboard. i would try sending it in to see what the problem is. connie
Jun 21, 2007 | iRiver Clix Digital Media Player
iRiver Clix Digital Media Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
