Question about PC Chips P25G Motherboard
No Power On Start
Hi i installed a PCChips P25G motherboard w/2.6/256/800 P4. w/2(1gig DDR400 Ram). Problem is when i turn the power on nothing happens .. The power supply works on any other board. P4 Chip tested on other board works (but only as a 1.3 since the board is only 400 FSB) Ram works fine on other board also. Even tried turning the power switch pins around.
Problem Solved, changed the power supply with a 450watt one and it booted fine .
Posted on Jan 30, 2009
What ram does a pcchips take ddr2 slot's being used combine with Pentium d and a 6600 gt
Thanks for posting your question. This took me a ton of time to find. Please leave me a great rating on this answer for finding the solution.
DDR400+DDR2 533 Supports Single-channel DDR2 533/400 DIMM and Single-channel DDR400/333 DIMM. Users can use either DDR2 or DDR memory modules.
Again, please leave me a great rating on this answer so others may benefit from this solution too!
Sep 24, 2011 | PC Chips P23G Motherboard
Vt8237r Via chipset Mother bord Ver: P25G Vga Driver missing .Plz give me driver
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=358&CategoryID=1&DetailName=Driver&MenuID=45&LanID=0
Jul 12, 2011 | PC Chips P25G Motherboard
Want manual for a P21G V3.1 DDR400 mother board to connect the case power switch, reset switch, H.D.D.Led, and power Led
the manual for you motherboard is here
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=364&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
Apr 07, 2011 | Computers & Internet
P25g motherboard, monitor wont turn over
i think you need to try replace you're ATX power Supply or you need to try remove the other 1 of you`re memory...Thanks
Apr 23, 2009 | PC Chips P25G Motherboard
How do you turn off the on board graphics on a PCCHIPS P25G MB.
If you have not tried to turn off the onboard graphics in the bios then you should do so. When you start your you will be given the option to enter setup( sometimes it is the delete key or one of the F keys }. once you are there simply look for the onboard adapter and disable it there. be sure to save changes before exiting.
Mar 31, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Drives
You can find the driver here:
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=371&DetailName=Driver&DetailDesc=P25G(V3.0)&CategoryID=1&MenuID=39&LanID=0
Apr 20, 2008 | PC Chips P25G Motherboard
PC Chips P25G Motherboard Logo
152 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
