Question about Kenwood Excelon KDC-X592 Car CD/ MP3 Player
Security Code? My son has a 2001 Accord in which some body work was completed and they disconnected the battery. Now that we have the car back we have the display showing a security number which we have never seen before. Is there a solution?
    Problem Solver:
  • 11 Answers
It is an anti-thieft feature so the radio becomes worthless if it is stolen from the car. If you take your car to the dealer they can reset the radio. You will usually only need the registration from the car. They will usually charge a standard fee so call around for the best deal. The work will take approx. 30 seconds.
Posted on Jan 30, 2009
Won't start. No lights or power of any sort.
Check grounds. 3 main grounds are battery to engine, battery to body and engine to body. Sounds like yours is battery to body.
Feb 23, 2016 | 2001 Chrysler Town & Country
How do i stop car alarm on 2001 honda accord
Disconnect the battery, Make sure all your doors are shut. You can have the hood up, Then reconnect the battery. (I still had my hood up) Walk over to the passenger door. Use your key to lock the car, then unlock the car. Alarm turns off.hope this works for you
Aug 08, 2014 | 2001 Honda Accord
Something is draining the battery on my 1991 honda accord
Someone will need to disconnect the battery and check it to make sure it does not have a dead cell, then check the circuits on the car for a draw.
Aug 19, 2012 | 1991 Honda Accord
How to fix VTEC System Malfunction code P1259
It is the wire close to the VTEC valve solenoid plug be cut off. Sounds wired, but it happened to my 2001 accord EX V6 sedan. After I solder it back, the TCS light turned off. But I had to disconnect the battery for 5 minutes and put it back to reset the Check Engine light.
May 21, 2012 | 1998 Honda Accord
01 dodge caravan instrument panel lights do not light. Can't find a reason - can't find a fuse Speedometer , tach, nothing lights or works
disconnect the battery to let the body computer reset.
had the same problem with mine when my son left center interior light on . it ran down the battery and the security system made the head light start flashing . when i jump started it i had no instrument panel lights . i disconnected the battery and it fixed the problem.
May 21, 2010 | 2001 Dodge Caravan
I need to program my 2001 Honda Accord 6 disk CD changer after I disconnected the battery. I don't carry a manual for my car and would like to solve this problem soon.
you will need serial number from audio unit,then call honda dealer with serial number and they can then look up anti-theft input code for you
Dec 30, 2009 | 2001 Honda Accord
2001 honda accord cd disc changer wont work
2001 honda accord with three cds stuck inside. Wont play or eject just a whooring sound and error on display. Any ideas before going to the dealer?
Jul 09, 2009 | 2004 Honda Accord
IDLING PROBLEMS ON 1992 ACCORD EX
Have the Idle Control Solenoid Valve cleaned up.
Or it might be defective. See steps below to check...
  1. Disconnect idle control solenoid valve electrical connector.
  2. Disconnect upper hose to solenoid valve from manifold and apply vacuum to hose. Valve should hold vacuum.
  3. Continue applying vacuum to hose and briefly energize valve by connecting battery positive terminal to the black/yellow wire terminal and negative battery terminal to the green/black wire terminal. Valve should not hold vacuum when energized.
  4. If idle control solenoid valve fails to perform as outlined, valve is defective.
Jun 03, 2009 | 1991 Honda Accord
2003 Accord. Navigation/radio/display system does not load.
I've reads post here suggesting disconnecting the battery for one hour. Couldn't hurt to try it.
Also try ejecting the Navi Disk, inspecting it for any damage, wait a few minutes and reinserting. The disk contains not only the navigation Database, but also part of the operating system.
DO NOT TRY INSERTING A OLDER NAVI DISK OR ONE FROM ANOTHER VEHICLE, THAT COULD DESTROY THE NAVI UNIT!!
If you need a new Honda Navi Disk, order it direct at https://www.hondanavi.com/Hondadvdsales/naviorder.php
Good Luck
May 05, 2009 | 2003 Honda Accord
Honda Accord 1995 Stereo and Clock
it sounds like you have shorted out the stereo. i had a jensen stereo that the display went out on an i checked all the same things that you did an it still wouldnt work. you may could take it apart an look at the circuit board an see if there is a burnt spot or a wire popped free from the board. for future advice always disconnect your battery. i hope this may help
Oct 23, 2008 | 1997 Honda Accord
Kenwood Excelon KDC-X592 Car CD/ MP3 Player Logo
191 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
