Question about Philips TP2784C TV
No remote, channels locked on smart tv
Philips magnavox smart series, no remote....channels locked
  • Anonymous Mar 19, 2014
    I have dany smart tv tuner D-300 but now I forget my password for a channel lock
    Problem Solver:
  • 8 Answers
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Posted on Mar 15, 2009
I have just been given a hand me down Philips Magnavox Smart Plus Series TV, but it is giving me a code, ,and I do not have a remote control, how do I get to channel 3
You may have to purchase a programmable remote control as a replacement and use its code search feature to find a code that will control your Magnavox TV.
Feb 05, 2015 | Philips Televison & Video
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Need instruction book
I was unable to locate your specific model using the information you provided however here is a link to the Philips website.
http://www.support.philips.com/support/html/index_us_en.html
They have a diagram to identify exactly which numbers they need to identify the appropriate manual. From there it should be a simple download to get the information you need.
I hope this helps, good luck!
Kym McC
Oct 11, 2008 | Philips Magnavox Learning Universal Remote
NO SOUND/CLEAR PICTURE
Please do not do all caps. It makes it harder for us to understand your problem.
Check the speaker settings in the menu and in the case, BUT NOT UNTIL IT IS UNPLUGGED FOR ABOUT 10 MINUTES! TVs have caps that hold up to 30,000 volts and take a while to discharge.
Oct 05, 2008 | Philips Magnavox Learning Universal Remote
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips TP2784C TV Logo
417 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
