Question about Philips TP2784C TV
Philips magnavox tv, no remote....channels locked
I called Philips at 1 888 744 5477 and they solved my Access Code question thusly.
Default Code is 0711.
Hope I can submit this now, AND that it helps someone.
Posted on May 18, 2009
  • ruth quiles Nov 14, 2011
    Thank you I used the code 0711 and it worked on my tv thanks a million
  • 80 Answers
You should use the keys on the tv for unlocking the channels.by pressing together the last two switches of right side you will enter in the menu.since your tv is flat model there may be difference.please use your tv users manual.philips duplicate remotes are available in the market chaply.original ones are costly. if you are convinced please rate me
Posted on Mar 02, 2009
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Tip
I have an Orion M TV/1331A, certain channels are locked, ex. 21, how do you...
Hey I have a Philips Universal remote for an Orion tv. My remote is the following: Model #: PHL PMDVR8K The only way I found my Model was on http://www.circuitcity.com/ccd site. Then I found http://www.fixya.com I called the Philips Accessories # 919-573-7854 and unfortunately there is not a tollfree number. I gave him the only numbers I could find on the remote where the batteries go. CL019, 36/05, and PMDVD6. He had me hold the Code search button down until the light stayed lite. The press the tv button, the light should still be on, then put in 115. Last hit the power button & it worked!! I hope it helps out everyone that needs it.
on Mar 13, 2011 | Philips Magnavox Learning Universal Remote
I purchased a Philips Universal Remote PM3S/PM3ST and can not get the code to operate my Magnavox TV. I tried every code and every possible code search method.
press set
press tv button
then push channel up button, repeat until channels change
press set
press power and see if it goes off
good surfing
Mar 06, 2009 | Philips Magnavox Learning Universal Remote
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Can't get the tv to move from the cable mode
Wondering if this is what your asking about, I cant find reference to Cable only mode...
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Aug 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips TP2784C TV Logo
1,068 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
