Question about Makita 18V 1/2"CRDLS Drill Kit
I took the drill apart and the gears all came out
I need a sequence on how to re-install the gears
  • 2,176 Answers
If this is a Makita tool I would go to Makitausa.com and type in your model number to look at or download a parts diagram for this tool. Let me know if you need further help.
Posted on Jan 31, 2009
Gears fell out.took apart to replace balleries. can not put the gears back
The gear box of cordless tools is generally and comparatively simple. If you are sure all the parts are present I suggest you engage a member of the family who has the tenacity for jigsaw puzzles to assemble it.
Jun 26, 2015 | Drills
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
I have 3 of these and all of them have a problem after a while that they slip the clutch even when it is selected to the drill position, can the clutch be adjusted?
I just took mine apart and it appears that you have to replace the entire transmission. It is an easy job and the part is about $34 much cheaper than a new drill. Really, it is one third the price of a battery. Just take the 4 screws out that hold the metal case to the plastic clamshells, slide the front of the drill off, pull the transmission out of the rear of the drill put the plastic piece with the gear indicator on the new trans, if needed, slide the new trans into place, spin the motor if needed to get the output to line up with the planetary gears, slide the front of the drill back into place, rotate the chuck to align the shaft  with the transmission output, put the 4 screws back in, enjoy.
Might want to replace the brushes while you are in there as well. I am going to consider this the dewalt version of an oil change
Dec 29, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Craftsman C3 19.2 volt Drill / Driver took apart pices fell out need to put back togetterneed a diogram
first comes the motor, next a gear, then five gears in the planetary gear, then a ring gear, next four gears and another ring gear, finally the gear that goes on the chuck shaft.
Oct 22, 2009 | Craftsman Drills
DW988 1st and 2nd gear doesnt work, 3rd gear works
You may have put it back together wrong, but you may also need a new transmission. 99% of the power tools I work on where the gears are slipping is caused by the transmission or gear box (both names are used interchangeably).
Good luck to you!
Don-www.toolsandmachinery.com
Feb 19, 2009 | Dewalt Drills
Bosch VSR1199 hammer drill
Check to make sure part number 30 is not stripped out or the edge knocked off. I can't find a part number on Ereplacement for them but I am sure that Bosch would have it. It sounds like you are on the right track and the way you describe it the gear is bad and like I said I think the keys might be bad also
Jan 27, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita 18V 1/2"CRDLS Drill Kit Logo
138 people viewed this question
Top Makita Drills Experts
John Trevino
EugenesDIYDen
EugenesDIYDen
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
