Question about Baby Lock Evolve
My Evolve veers off the fabric when it comes to something thicker
It seemed to be stitiching perfectly well then started to veer off and not advance when it came to a thicker piece of fabric eg crossing a seam. I have tried new needles, new blade but it still does it and has become worse. It now wont really stitch well either. Still cover stitches well though. I was told that there were 2 sets of blades but one I shouldn't try to change myself.
    New Friend:
  • 186 Answers
Sounds like you need new blade(s). You can probably change the upper blade which usually wears out first. The lower (fixed) one is more difficult.
Posted on Jan 30, 2009
I have been given a Babylock Evolve overlocker and am having difficulty in adjusting the stitch so it doesn't extend over the edge of the fabric
Sounds like your looper tensions are too loose. If the threads are "slopping" over the edge of the fabric, tighten the looper tensions.
Jul 19, 2017 | Sewing Machines
I have a babylock evolve serger. It serges fine w/o the blade engaged. Once I engage the blade, the stitches don't hit the fabric
most Sergers have a blade adjustment that allows you to move the blade closer to the sewing plate as well as further away sounds like yours may be to close to plate. Open the door to the underside of your sewing machine; their should be a round knob at the base of the blade are. Turn the blade until it moves away from the sewing plate. test and see if you have adjusted it enough so as not to cut your stitching off. hope this helps
Jan 11, 2015 | Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Needle sways while stitiching creating uneven lines.
Two things come to mind. First, if your bobbin and upper thread tension are too tight, they may be pulling the needle out of line. More likely though, is you do not have the correct needle for the weight of fabric you're using. For example, a heavy jean type denim will require a thicker needle than a thin sheet type of cotton. Your sewing store can help you select the correct one.
Nov 19, 2013 | Brother Disney PE-400D Computerized Sewing...
The tread gets all tangled on the bottom of the fabric
You seem to have a threading error. Try re-threading top and bottom threads completely. Sometimes the thread does not pass through the out of sight tension discs correctly.
You may also have something stuck in the discs so pull a thicker thread through by hand to clean.
If this does not work, find a spare piece of similar fabric and set all the visible tension discs to "0" and try again, then work through each one by altering the tension slightly each time..
Dec 08, 2010 | Brother LS-2125 Mechanical Sewing Machine
Needle keeps breaking when sewing
Make sure the needle is in correctly. On most machines the flat part goes towards the back of the machine. Also make sure you are using the correct size needle for the type of thread and fabric you are using. Thicker fabrics such as denim and upholstery fabrics will require a thicker needle, like a 100 (16).
Sep 04, 2010 | Juki TL-98QE Mechanical Sewing Machine
Stitiching too loose
The top tension pulls the upper thread up to the top of the fabric. The bobbin tension pulls the lower thread to the bottom of the fabric.
An even stitch is a tug of war between the two.
If it looks good on the to and the bottom looks loopy, the bottom is dominating and the upper tension needs to be increased to pull the knots up.
If the thread on the top looks like a straight line, it is too tight on the top or too loose on the bottom.
Unless the bobbin case tension has been adjusted, the problem is usually on the top.
Jun 18, 2009 | Brother CS-100-T Computerized Sewing...
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Apr 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Trouble starting a seam
Evolve is a serger and can't sew backwards. Start on a scrap and then onto fasion material and then cut off scrap. You'll have to use fray check where cut or it'll pull out. I'd ask your dealer. It shouldn't do this. Do you start w/ a thread chain? You have to except for the chain or cover stitch where you have to start on material.
Feb 18, 2008 | Baby Lock Evolve
Sewing Machines Logo
120 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
