Watches Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello http://www.amazon.com/Colibri-AMC029800W/dp/B000WP9MFM the digital time/stopwatch/date/alarm is working fine, but the analog part is not ticking, I've tried winding it to no avail. Please help
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 31, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813854
Points
13579
This is not common to have two different movements in one watch ( mechanical and electronic).
I'm pretty sure that the analog part is battery driven, so, no need to wind it. You may have the watch with two separate batteries, each one feeding its own movement. Check if you have this version and replace the analog watch battery.
If there is only one battery in watch, then the analog part is faulty or the battery is underpowered.
In this case you will need the help of the watchmaker.
Do not forget to rate, please.
1helpful
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 • Watches
Aqualite stopwatch manual
To change the alarm settings on the Aqualite Men's Analog/Digital Watch, press the bottom left "Mode" button until you find the "AL" word next to your alarm time. Then let go of that button. Then press the top right (Start/Stop) button one, two, three, or four times to select your options (alarm on, alarm and chime on, chime on, alarm and chime off)
Jun 03, 2012 • Watches
3helpful
3answers
I can't find the user's manual for this watch: Armitron Sport 40/8125BLK Watch
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
15helpful
3answers
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
6helpful
Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Sep 17, 2008 • Watches
14helpful
3answers
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 • Watches
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
