Question about Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23
My mig wire melts inside base unit when trigger is pulled
I have a lincoln 3200hd mig welder, and as soon as i press the trigger, the wire between the spool and the feed unit gets red hot and then melts. i have pulled apart the feed hose from the base unit and cleaned everything. still melts. any ideas????? thank you
    New Friend:
The above information is not correct.
The entire wire is polarized by the tip during normal operation, making the entire supply of wire is polarized to whichever polarity is selected. The cabinet of the welder is usually bonded to the output, and so therefore is the spindle on which the reel is kept.
You are using a spool that has the wire anchored on the outside of the reel, rubbing on the spindle assembly, and making a sliding contact.
Put an insulator between them. A circle of thick cardboard (not corrugated) with a hole in the center can work well, as do plastic lids- Cottage cheese, tub of grease...
Posted on Dec 09, 2012
  • 56 Answers
Your liner is grounding some place make shure the tip is not touching any thing but the answer to your question is there is a direct short in your feed hose or tip or liner
Posted on Jan 30, 2009
Hot all the time
relay / contactor has stuck in the on position
Jun 15, 2013 | Lincoln Electric LE 83180 Century...
Lincoln welder wiring diagram
Which model?
Lincoln does ahve the diagrams in the manuals available here:
Operators Manuals ' Lincoln Electric
Dec 16, 2011 | Lincoln Welding Tools
I have had my Pro-MIG 140 for six years, never a problem. Pulled the trigger today, the wire got red hot and melted at the drive gears. Is this a problem with the liner? or something else? Im in the middle...
If you can feed the wire manually(by hand) the liner should be OK. I would replace the tip and verify all the welder connections at the drive wheels. Make sure all the connections are clean and tight.
Mar 08, 2011 | Lincoln Welding Tools
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
No wire feed
If the power to the unit/fan is on and the relay clicks the fuse is not the problem. Check your motor connections. Either you have a bad motor/wiring to motor or motor speed control board.
May 22, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Logo
321 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
