Question about Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW
Water in the floor
I have an upright 17 cu.ft.frigidaire freezer that worked fine until I moved.Now I find puddles of water in the floor in front of the freezer.
  • Patricia Hamilton Jan 30, 2009
    Thank you very very much.God bless.
  • Anonymous Mar 20, 2014
    it clicks like it's trying to come on but it doesn't. sometimes it runs fine
I have a frigidaire freezer FFU1767FWO. The display on the outside of the door is out sometimes. Can you give me something to check for.
Posted on Mar 06, 2010
  • 410 Answers
There is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Posted on Jan 30, 2009
Blue liquid drains from bottom of freezer
you have refrigerant on the floor you need to A&E FACTORY SERVICE @ 1-800-862-9226.
now you can not do it yourself you need a trained technicians to do the work
Jan 16, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water pools at bottom fridgidaire freezer
sounds like your drain is plugged up....call for help on solving problem...
May 12, 2010 | Frigidaire 17 cu. ft. / 481 liter Upright...
Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 18, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Upright with door lock 13.7 cu. ft.
hi tanks for the question is there water inside on the floor of the freezer.if not check the drain tube under the freezer at the back could have a clogged drain hose thanks the appliance doc
Aug 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
542 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
