Question about Fisher Paykel EcoSmart GWL15
Blockage? pump not pumping
My Fisher & Paykel Smart Drive washing machine (13-15 years old) wont pump water out... it just makes a buzzing sound. seems like there may be a blockage somewhere in the pump inlet?? I've taken the top off, but can't get the spinner out. there are three screws way down in the middle of the spinner... should I try to undo them. i'm worried they could be hard to put back in.
Thanks!
Mark
  • wealthzone Feb 01, 2009
    my fisher & paykel alba autowasher wont empty suspected block. can you tell me easest way to fix if blocks at pump. have done older models not sure where to look on this one. serial no:apt 525534
    thanks
  • 42 Answers
Did one of these for a mate the other day, removed the four bolts on the pump on the bottom of the drum, one of them is in a ***** of a place (pump has a red fan on the bottom of it) found 3 coins in there. Also removed the drain hose and found gunk jammed up in there, cleaned it out, good as new! When I pulled it apart I took the whole drum out of the machine (big mistake) it's a lot easier to turn it on its side, and I say side because if you lie it on its back I'd say the water in the drum will pour straight into the circuit board
Posted on Mar 10, 2011
  • Fisher Master
  • 8,220 Answers
Naw go for it, the pump is probably got a bra underwire or coin in it. Thong maybe?
Posted on Jan 30, 2009
    Genius:
  • 2,920 Answers
Yu should go ahead and check the pump chances are there is a sock or something else stuck in there keeping it from draining...its right on the bottom of the washer
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
Washer won't spin or drain water
Sounds like a blocked pump (turn on, advance thru to spin, press start- do you hear a humming noise? if yes, pump is blocked).
Disconnect from power.
Manually bucket as muh water out of machine as you can. Then lean machine over so you can access underneath machine.
Drain pump located right front- it has a kind of fan blade at the bottom. This fan blade should turn very easily- if not, there is a blockage.
-To remove pump, remove plug wires from pump (1 plug with 2 wires, 1 plug with 1 earth wire). Then there is a white plastic tag located at the top of pump-pull this gently towards you, and turn whole pump assy anti-clockwise. Pump assy will drop out easily- do not force (note- water will come out too- put down some towels!!) Remove any blockage from pump, and reach fingers into bowl where pump has come from to check for any blockages. If OK, reassemble and retry.
Aug 08, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
Water wont empty
We had the same problem with ours. I took out the steel tub and found there was a lot of lint blocking the pump (at the bottom of the plastic tub). There is a screw holding the pump cover. Once you remove this you can check it properly for blockages.
May 25, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
179 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
