Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Steamer working only intermittendly
I can get hot water, but when I run the steamer, you can hear a pump go pump-pump-pump-pump. First I get some squirts of water (5 seconds), then a little steam (5 seconds), and then nothing (20 seconds). Then the cycle repeats.
Problem started today after using machine for 3 months.
  • 1,089 Answers
Hi
Have you tried to descale your machine. Remember to use the correct descaling powder and make sure that it is totally dissolved before running the descale program. In the menu, make sure that your water hardness is set on 4. descale more often than not enough.
Posted on May 24, 2009
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
Miele CVA615 won't produce steam or hot water. Machine makes a mechanical noise like it's trying but no water comes out. The expel air indicator was on and this preceded discovery of the issue. Steamer...
Trey -
It sounds as if the water pump has gone bad. If the machine will not put water out of the hot water spout or the steam spout, and there is no water in the base of the machine (leaking from pump) then the pump is not putting out any pressure. The sound you hear is the pump running - but no pressure behind it.
Dec 30, 2013 | Miele Coffee Makers & Espresso Machines
Hot water suddenly runs cold
Can you hear the Head fire up when it calls for hot water? Maybe the pilot is clogged
Jul 04, 2013 | Cleveland Range OGS-12.20 54" Gas-Fired...
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
No water coming through coffee filter. I have descaled twice. You can hear the pump but no water and then it goes quite with no water. I have tried to prime the pump but still does not work. The steamer is...
If you open the steam tap while the pump is running does water come out? if so then you might have a blockage in the coffee solenoid or the bottom of the boiler. Do you hear a 'click' sound when you hit the coffee switch? If not the coffee solenoid may not be operating. The most common cause of the problem you are having though, is scale flaking off the boiler walls causing a blockage where the coffee water comes out. Try hiting the coffee switch, opening the steamer and then if water starts pumping out, close the steamer and see if water starts flowing out the coffee group. Do this without the portafilter (coffee holder) in place.
If you do get water flowing trough the group, try backwashing the machine.
If these things dont help then you should take it to an authorised repairer or open up the boiler yourself if you are a handy person and have access spare parts. Good luck, these machines can make a great espresso when in the right hands and working order.
Dec 01, 2010 | Gaggia Classic Espresso Machine
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Cannot express the coffee into the cups
Solution nr one cold be the machine ran out of water and the circuit need to be filled up again.
This is the procedure to do that
Fill up your water tank
Open the steam knob na push the coffe button...in that way the water will be forced to go to the steamer.If you have water in the steamer like you asking for hot water....go to the next step
Close the steam knob and at that point you will hear a different noise and the watewr should be able to go direct into the boiler and start dripping like it was before.
if you don`t have hot water coming oput from the steamer....the problem is before the boiler and could be a clog on the silicon tube or the water pump is loosing friction..
Pls don`t forget to rate your experience
Fabio
Apr 26, 2008 | Saeco VIA Venezia
Nespresso D290
I hear you!! I found that you have to press the green steam light (left side) TWICE before steam is ready. After your second press, the machine will make pumping noise, then all lights will come on. From that point, the cappucino/latte steamer will work as manual describes.
Apr 18, 2008 | Nespresso D290 Espresso Machine
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
195 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
