Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
In both my car cradle and my home dock I have to put a piece of paper behind the radio and try numerous positions with the paper to get my radio to charge or even play. It doesn't seem to charge at all in the car cradle. It seems to me that the contacts have loosened on the radio since it doesn't really sit right in either cradle.
  • kamelot656 Feb 07, 2009
    I have two of them and they are both junk. I can't get mine to do anything
  • norcal_parro Mar 17, 2009
    I have the same problem and use the same method you describe...the problem is getting worse, and I fear soon I will not be able to charge the unit even doing this.
    Problem Solver:
  • 13 Answers
I posted on this myself looking for solutions, and then discovered the solution my self. The base pin connectors at the bottom of the receiver apparently become loose, and in order to make a good connection you need to push/pull the top of the receiver forward to achieve a connection. In the car cradel, I do this by jamming something between the receiver and cradel at the top to force and hold it forward). In the home base, I pull it forward at the top, and prop it that way with something heavy behind it. No one ever posted on how to take the unit apart and actually fix the loose connection.
Posted on Feb 28, 2009
Delphi roady2 SA10085 XM Radio Receiver with Car Kit
Sounds like its the dock itself. Have you tried using the home dock with the vehicle power or visa versa? This should help you confirm what the problem is. You can get a replacement power adapter here:
http://www.tss-radio.com/products/xm-car-power-adapter-for-6-volt-receivers
A cradle may be difficult to find, but TSS Radio can help you look.
Jun 05, 2012 | Delphi Roady2 SA10085 XM Radio Receiver...
My roady xt does not have a fm select option on the menu
You need to have it in the AUTO base/cradle - AND - you cannot have anything plugged into the LINE OUT or AUX OUT jack, as it will disable the FM transmitter. Try unplugging the audio output, then you'll be able to select the FM transmitter again. I believe that they removed the option from the HOME cradle/dock all together because of regular AM/FM radio stations complaining to the FCC that the transmitters were too strong (in other words, they wanted to hurt satellite radio competition or slow it down as much as possible by forcing Sirius and XM go back and redesign their radios for a much weaker or NO FM transmitter).
Nov 07, 2010 | Delphi Roady XT XM Radio Receiver
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Jul 08, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
Does pioneer have a car cradle for the inno2 that secures it better i have gone through so many of them and now my warranty is up. i operate heavy equipment and it causes my inno to fly out of the cradle,...
I feel your pain. Unfortunately, I haven't been able to find any car docks, there all discontinued. (sorry bums!)
But, when I'm riding my motorcycle, I put a rubber band around the radio and dock, holding it in place.
But, in a place that doesn't interfere with any buttons or the display.
Jun 06, 2010 | Pioneer inno2 Portable XM Satellite Radio...
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
May 08, 2009 | Delphi SKYFi XM Radio Receiver
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer Inno FM modulator
Make sure it is docked in the docking cradle for the car. The option will not come up if the unit is not in the docking cradle.
Apr 15, 2008 | Pioneer XM2go Inno Satellite Radio...
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
150 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
