Question about NetGear WG311T 802.11g/b Wireless Adapter
Trying to install a Netgear WG311T 54mb pci adapter
Need wep hex code or phrase to connect
    Sergeant:
  • 219 Answers
To get that information you need to log in to your router's control panel. To access that you need a computer (Any Windows Computer) to be directly connected to your router via a CAT5 (Ethernet) cable. If that means you have to move a computer closer to the router, do it. Otherwise you won't be able to retrieve the information.
Once connected via a CAT5 cable, go to Start>Programs>Accessories>Command Prompt. Type in: ipconfig
Press ENTER to execute the command. A list should appear with a few IP Addresses listed. You want to locate the IP Address associated with the, "Default Gateway."
Now open your Internet Browser (Internet Explorer, Firefox, Etc...) and type the IP Address associated with, "Default Gateway" into your Browser's address field. DO NOT add www. or .com. Now press ENTER or GO as if you wanted to visit a website. Your router's control panel should appear.
Now you will need to log in to proceed. If you do not know your default user-name and password try googling your router's model name/# adding, "default password" at the end. Example: Linksys WRT54G default password. If the default login/password doesn't work you're going to have to call the company that made your router and ask them for assistance in resetting your router's login username and password.
Once you managed to log in to your router's control panel, find the Wireless Security region. Just browse around if you have difficulty finding it, as long as you DON'T change settings you won't hurt anything.
Once you find the wireless security region you should be able to pull information on the encryption type (WEP WPA), the channel (1-12), and the security key. If for some reason you need to, change the encryption type, channel, and the passphrase for your convenience, feel free to do so. However once you find the wireless security page you have all the information you need to connect your wireless adapter to the router.
Should you still have difficulty connecting, try changing the, "Wireless Mode." Sometimes, "Auto" doesn't work and you'll have to try different modes.
I hope you get the problem resolved.
Posted on Jan 30, 2009
Can't connect with i phone when wep security used
WEP "Security" has been completely and thoroughly hacked. It is pretty useless. WPA requires that you pick a good passphrase which is not dictionary based.
But my guess is that you have not entered the security key correctly. Stupid WEP should have included a checksum in the entered key. Make sure you use the hex key, and not the phrase that generates the hex key. I have had poor luck moving those and never encountered a problem with the hex key, unless I miscopied it.
And switch to WPA security.
Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
Need to know where I can get driver download.
Possible causes:
1)The Operating System on the computer might not support the Plug & Play feature or need latest system updates.
2)The USB port or PCI slot on the computer might be faulty.
3)Extension cable (if being used) that connects the USB adapter and the computer might be faulty.
4)There is no driver support for the Operating system.
Symptoms:
1)LED will not light up on the adapter.
2)Found New Hardware Wizard does not come up.
Resolutions:
1) Make sure you meet the minimum system requirements for the adapter and have the latest updates on the computer.
2)Use the latest driver for the adapter. Latest drivers link is mentioned below.
3)Try a different USB port or PCI slot on the computer.
4)Try another device and check if it gets detected.
5)Try to connect the adapter directly to the computer without using an extension cable.
6)Try restarting the computer or try adapter on a different computer.
Open the below link and try to download the latest version of the driver http://kb.netgear.com/app/answers/detail/a_id/747
May 18, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Netgear Wireless adapter
1. Windows not shutting down may be due to mouse incompatibility. e.g Toshiba with Logitech Mouse. Microsoft mouse works better with Toshiba in my view.
2. Set modem to NAT mode, ensure pass phrase upper and lower case preserved on your wireless machine (case sensitive).
3. Transfer WEP or WPA-PSK[TPIK] pass phrase to your Netgear Wizard as a Hex Key (Key 1).
Jan 15, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Can a wireless card work with a router from a different brand???
Hi Ginger,
To answer your question, No they do not have to be the same brand.
Just make sure you know the information needed to connect to your wireless network, such as the SSID, Security-type (WPA-PSK, WEP, etc.) and offcourse the key/passphrase.
If you need more help, let me know.
Regards Ronnie
Jan 11, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
How to lock my netgear router
Thats usually pretty easy, Im not familiar with the netgear program, but its possible to do it using the windows wireless utility, by clicking the setup wireless network option, and putting in an key for WPA or WEP protection.
HOWEVER
I did find this and looks pretty complete and easy to follow.
link: http://www.lycoming.edu/acad/Netgear%20Wireless%20Router%20Setup.htm
Apr 24, 2008 | Computers & Internet
Computer Crashes When using this Netgear device
Try downloading the latest drivers for this device and install. See the website below. http://kbserver.netgear.com/products/WPN311.asp
Apr 20, 2007 | NetGear WG311T 802.11g/b Wireless Adapter
NetGear WG311T 802.11g/b Wireless Adapter Logo
162 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
