Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
LD is on my display-nothing will clear it and washer doesnt drain
My Whirlpool Cabrio washer keeps reading LD and won't restart or nothing. It has water in the tub. I tried unplugging it and starting over, but it won't do anyhyingMy Whirlpool Cabrio washer keeps reading LD and won't restart or nothing. It has water in the tub. I tried unplugging it and starting over, but it won't do anyhying
  • 1 more comment
  • dwp1220 Apr 04, 2009
    The noted solution fixed my problem. You'll need a wet-vac to empty as much water out of the tub before removing the hose ( I have a 10-gal). It was also very helpful to have a spill/overflow tray that the washer sat on when the pump hose was removed. This captured the water flowing from the hose while the wet-vac was sucking the water out of the tray. Never got a wet spot on the carpeting in the laundry room using this method. The rubber hose between he tub and the pump was a bear to get back on. I had to switch to band clamp as I couldn't get the hose back in place with the existing clamps. Good Luck!!
  • Anonymous Mar 14, 2014
    serial number wtw7600xw2
  • Anonymous Mar 21, 2014
    bearings very noisy on cabrio washer
  • 318 Answers
The ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Lo error code in cabrio
There is no "Lo" code I can see in the service manual, but there is an "oL" code which flashes when the machine/motor control detects a load size that exceeds the washer's capacity. Open the door lid to clear the display, and remove excess laundry, then close the lid and restart the cycle.
There is an "Ld" which related to a Long Drain when the water level doesn't change after the drain pump is on. Need to check to see if the drain hose or the drain pump is clogged.
Jan 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain. Keeps flashing LD
LD means long drain time need to pull pump and clear.
If that doent work replace pump
Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Oct 20, 2009 | Whirlpool Washing Machines
LD appears. I cannot shut off unless I unplug it
Long Drain you may have a something in the drain hose or drain pump or damaged drain pump.
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  Press STOP/CANCEL to clear the display.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRLPOOL CABRIO WASHER
LD means long drain and will require a drain pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD light
umm. thinkin perhaps something flaoting around on the drain pump house perhaps causing partial restriction of drain capability.new pump doesnt maen something cant get struck in impeller
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
try to remove as much water as possible ..wet vac will help pull unit out remove back cover lean washer forward on left bottom is drain pump remove 3 screws holding pump and clamps holding hoses on pump..on motor side of pump are 4 screws remove them noting location and orientation of pump body clean out ..ck impeller ..round white part with fins ..if it is not broke try turning it by hand should turn but with some resistance if free wheels replace pump if you found stuff in pump reinstall and ck
Aug 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
This is another possible solution, more than likely most people will expierience clogs. I had the same problem today, upon removing the drain pump I noticed one of the dark blue wires was off of the connector that plugs into the pump, seems these are held in place by a "splice connector", and is a simple fix, after you unplug it from the drain pump take the connector and pull from the front and rear to open the splice jaws, re insert the wire and push back together. Plug it back into the pump, and that's it!
Dec 30, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,182 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
