Question about Lexmark X5150 All-In-One InkJet Printer
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
  • 64 Answers
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
Posted on Jan 30, 2009
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
mearmi@hotmail.com
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
The pages on the right side come out faded or not printed at all. The printer is only a couple of years old, no more than 5-10k total pages printed. On second set of cartridges.
Hi
If its happening with single shade color
1) Take the Cartridge out of the Printer and shake it
2) Clean the cartridge drum with the Tissue Don't Rub slightly clean it
3) Take the Cartridge out and shake it
If page comes faded on every print Black or Color then there must be a Roller issue which is not clean
1) It could be the Roller side is not clean -
Need service for the Printer
Jan 03, 2010 | Konica Minolta Magicolor 2450 Printer
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
HP 3200 Photsmart Printer will not print properly.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Jul 19, 2009 | HP PhotoSmart 1215 InkJet Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
1200 series lexmar printer
My printer won't print neither black or color cartridges; it marks that it had 75% ink
remaining. How can You help me to find out what is the problem if is the printer or the
cartridges. Its been a year I bought the printer but it was in storage around 6 months.
I would appreciate if You can find the problem and the solution.
Thank You for your time.
Feb 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Lexmark X5150 All-In-One InkJet Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
