Question about Acer AOpen MX 3ZA (91.88110.101) Motherboard
Heat on n1996
When the cpu heat acer n1996 don't work
  • Pratheesh_tn Feb 23, 2009
    I need to get the pin configuration of Acer 7600G motherboard.(N1996)
    Especially the front panel ON/OFF.
    When i swich ON, CPU fan not working(Mother board does not statrs), but the SMPS fan starts running.
    Actually i dont have the pin details of this motherboard.
    So please help me.
    pratheeshtn@gmail.com
  • 106 Answers
You may need to clean the heat sink, fan, and the processor.... put some silicon wax between the heat sink and in the processor.. ^^
Posted on Feb 09, 2009
No display in MSI N1996
central processing unit CPU
as it says it processes all information that runs a computer
hope this helps
Jun 19, 2012 | MSI Computers & Internet
Acer Aspire 4930 heats up very quickly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
Can I upgrade my 2.8 Ghz CPU with the 3 2 GHz dual core 775socket BX80571E5800 CPU into my N1996 acer 671t desktop motherboard, and can I upgrade my 553/ddr2 ram with a 2nd 2G ddr2 800/ RAM (max 4x 1 G...
as long as the socket is exactly the same as the processor you are trying to upgrade to you should be good. As far as memory goes you can use a faster ddr2 chip but you have to find out what the maximum capacity is on each slot. Most newer computers can support 1gb+ per slot. Always make sure you install ram in pairs and in the proper slots.
Mar 21, 2011 | Acer Computers & Internet
I need to download a sound card for acer n1996 but every site takes me to driverboost and i have to purchase it?? can anyone tell me how to get my speakers working pleaseeeeed
http://support.acer-euro.com/drivers/desktop/veriton_3600g.html
under "audio driver" you see Onboard Sound Driver for all MS Windows Versions ... click on it... and run the setup...
it should work...
ftp://ftp.work.acer-euro.com/desktop/veriton3600g/drivers/audio/audio.zip
one more thing ...
your motherboard model is not ACER N1996...
it may be MS 6772... or any other MSI model...
check your motherboard... under ACER 1996 you can see a small box with model name...
HAPPY HEARING...
Dec 12, 2010 | Acer AOpen MX 3ZA (91.88110.101)...
No power on N1996 argon motherboard. Cpu fans
if it's switching its self off after about 10 second then Your CPU Chip is not right some how it could be / damaged / the wrong socket type for the board as alot of CPU's are very simmler / The CPU's (4 pin) power supply is not connected or the CPU hasent gone in to the socket properly when this happens it will power up but will send no power to the monitor, or somtimes set off an alarm that sounds like a sciron going off.
May 05, 2010 | HP Compaq Motherboard
Mercury n1996.......AGP slot or PCI????
n1996 is NOT the model number. ALL MSI boards are labeled n1996 - it's their C-Tick number. You need to find the actual model number which should be listed on a sticker near the main CPU socket. Search for that on msi's website.
Let me know what the model # is..
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Apr 27, 2009 | Computers & Internet
Acer power fg does not start up for a long time. if it does start then it can just shut down with no warning and then will not start up again. fan is working when the pc is running
Your heat sink is not properly working. this is because when cpu heat crosses threshold it shutdowns it self. it will not start again until it cools.
Try to remove the heat sink and then clean the base of heat sink which sits on cpu and apply the cpu thermal interface material. this is obtained in any computer accessories shop. shouldn't cost much. if available go for Cooler Master Cpu interface material.
Apr 22, 2009 | Acer Power FG (APFGUP5161) PC Desktop
I NEED acer N1996 CE MOTHER BOARD DRIVER .PLEASE HELP ME
I wan'to download Acer n1996 VGA &AUDIO DRIVERS
Mar 11, 2009 | Acer Computers & Internet
PC WON'T POWER UP
With nothing attached to the mother board except 1 stick of RAM in the first slot the power supply and monitor attached, and then  it still turns off ; I would make sure the heat sink was clean Reseat the Cpu and try it again. Now if the same results. I would attempt to substitute a different known good power supply. If that would not work, you are down to substituting a different CPU .
Dec 09, 2008 | Intel Motherboard
Sud card
Download here at acer:
http://support.acer.com/product/default.aspx?modelId=453
If this is the wrong model search by desktop model and number.
Example: Acer Veriton 7600G
Good luck
Jul 10, 2008 | Acer AOpen MX 3ZA (91.88110.101)...
Acer AOpen MX 3ZA (91.88110.101) Motherboard Logo
814 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
