Question about Canon imageCLASS D760 All-In-One Laser Printer
Paper jam on the ouy feed roolers
I have a paper jam on the out feed of a canon d760 copy machine
  • 62 Answers
Outfeed? u mean the fixing assembly?? where the paper gets warmed?? u need to unmount the panel, open the cartridge cover and unscrew. the slide panel and carefully unplugged the flat cable.
then you need to remove the platten glass. remove left small cover and then remove platten glass. remove the black cover besides the scanner. now remove the left covers, all of them, and unplug the fixing assembly. they are at least two connectors that go right to the power supply board. now you need to unscrew the fixing assembly, see the top of the recently uncover top, you must see two holes, thru them you should see screws, two on one side and one on the other, unscrew them, and then you will finallly release the fixing assembly. now that you got it out remove the plastic cover if it's there and then remove the two screws that has one on each side, now rmeove the metallic cover, you may need to unlock a little metal locks on the sides, push or pull depending situation and then finally free the unit from its cover. at this point you must be really able to remove all the jammed paper. clean up with pressurized air if possible. now that is paper free you need to mount everything back as original. good luck!!
Posted on Jan 30, 2009
What does supply rec. paper mean in the LCD display
Your machine is not feeding paper correctly. Check for any obstruction in the paper path
Mar 27, 2015 | Canon imageCLASS D760 All-In-One Laser...
Check printer in canon image class d760
scanner bulb or mirrors of scanner must be having some dust on it.its easy to open the upper glass unit of scanner,jst open it carefully n clen the bulb ,mirrors n the calibration strip(black n white strip below the copier glass)with moist cloth.n refit it simply .ur copier will start copying for sure.feel free to ask 4 further asssistance.wish u success.
Jun 06, 2008 | Canon imageCLASS D760 All-In-One Laser...
I have d760 cannon copier. finally removed the
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Oct 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jams right before it exits copier
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
Feb 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Won't copy document through feeder.
When you say it won't copy, do you mean that the paper won't move in the feeder or that no copies come out? Do you get any error messages? Try using alcohol on a swab or lint free cloth and clean the feed rollers in the feeder. They sometimes get paper dust on them and they can't pick up the paper. Also make sure that any paper sensors that detect when paper is in the feeder are intact. Occasionally they get stuck or broken. Hope this works.
Sep 22, 2008 | Canon imageCLASS D760 All-In-One Laser...
Cleaning a Canon d760
I am not sure of that ,the best way to clean it is to do it manually by having the machine being serviced by an expert .
Dec 12, 2007 | Canon imageCLASS D760 All-In-One Laser...
Paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Jun 14, 2007 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D760 All-In-One Laser Printer Logo
249 people viewed this question
old marine
old marine
