Question about Linksys Wireless-G WRT54G Router
Cant connect to internet using linksys with att dsl modem
I can connect to the internet with just dsl modem connected but when i add in the router it will not let me online can't figure out the problem the router worked fine with digital cable connection
  • Peter Steiert
    Peter Steiert May 11, 2010
    Why are you using a router on a router? The AT&T DSL modem is a router (If it's the one I think it is. A 2wire.) The most recent ones also produce a wireless signal, so there's no need for your linksys, unless you just enjoy it.
Most likely you have a conflict with the first two numbers of your lan address for the router being the same as the modem. For example, 192.168.x.x and 192.168.x.x. Even if the last two numbers are different you can have conflicts. Disconnect your router from the modem and log into your router. Change the lan address for your router to 172.168.x.x, 172.16.x.x or some other first two numbers. After applying the changes, hook up your router too the modem and see if that solves your problem. It did mine. You may also need to set you user ID and password for your system on the second router. (Your digital cable connection may have had a different lan address that was not conflicting.)
Posted on Mar 17, 2009
Your router was configured for Cable Modem which is usually DHCP
Now you need to change it for DSL modem. This means you have to change WAN setting from DHCP to PPPoE and enter your Username and Password for DSL service (should have been provided by your ISP)
Some DSL modems that are also routers need to be accessed directly first and have their configuration changed to "passthrough". This means that DSL modem should not be handeling PPPoE login but rather should let your router do the login.
Posted on Jan 30, 2009
Cannot connect to att DSL through Linksys router.
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is, it may be having conflict with the ATT modem. Change the wrt54g ip to
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
256 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
