Question about Whirlpool LSR6334LQ Top Load Washer
Washer Doesn't move from cycle to cycle
I have a top load Whirlpool washer. At the end of each cycle I bang the washing machine top and it advances to the next cycle. This doesn't happen all the time but for every cycle, but always after the first. It's as if the bang or pushing the top down really hard triggers the next cycle. If I move the knob manually the cycle doesn't advance. Only the bang/pushing on the top does the trick.
  • 318 Answers
This washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Posted on Jan 30, 2009
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
My washer bangs very loudly on the spinning cycle
Three springs attach to that triangular bracket which will end the banging noise if reattached to the washers inner frame work
May 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer stuck in "fill" cycle
vacuum hose may be off on your pressure switch.take face loose and flip face back by pulling forward and up.your vacuum hose is clear and runs to your size load switch or pressure switch.if hose off it wont advance.
Mar 11, 2009 | Whirlpool WTW5520S Top Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin
The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
Oct 18, 2008 | Whirlpool LBR4121JQ Top Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
