Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
2005 POLARIS RMK RUNNING PROBLEMS
I HAVE A 05 POLARIS 900 RMK. I NEED SOME HELP FINDING OUT WHAT IS WORNG WITH IT. I WAS OUT RIDING LAST WEEKEND, ROAD FOR A COUPLE OF HOUR AND THEN STARTED TO TAKE SOME JUMPS. ABOUT THE THIRD ONE I TOOK TO SELD START TO RUN LIKE ****. IT FELT LIKE IT BOGING DOWN. I MADE IT HOME AND LOOK AT THE PLUGS AND THEY LOOKED FINE. THEN I LOOK AT MY GAUGES AND THE ARE ALL FLASHING WHEN IT IS RUNNING. I CAN GET IT STARTED BUT THEN THE GAUGES START FLASHING AND THEN IT DIES UNLESS YOU PLAY WITH THE GAS. I CHECK ALL THE WIRE CONNECTIONS THAT I COULD FINE BUT STILL NO HELP. I NEED SOME ADVISE OF THINGS I CAN CHECK WITH OUT TAKING IT INTO THE SHOP AND GETTING RIPPED. THANKS FOR YOU TIME
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Be sure to pull both sparkplugs out and test each cylinder for compression with a screw in compression tester available at your local auto parts store or on eBay for not much money. A lack of compression in one cylinder can cause the symptoms you mention.
Posted on Apr 10, 2013
  • John Dimmer Apr 10, 2013
Check all electrical connections
Posted on Feb 17, 2011
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
Reverse on my 2007 rmk is going into reverse on its own and toggling back and forth from fwrd to rverse winthen seconds wat shuold i be checking ?
My 07 RMK 600 did the exact same thing after a VERY wet ride on the sled deck. after i let it dry out it, then next trip we made it seemed to run fine.
were you able to identify the problem on your 07 RMK?
Jan 31, 2011 | Polaris New Genuine Polaris Snowmobile...
1997 Polaris rmk 700 has no spark. Kill switch is in run position and key is on. Sled ran fine last year. I get a little tail light when I pull starter rope
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
Jan 22, 2011 | Polaris New Genuine Polaris Snowmobile...
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
I have an 2002 polaris Rmk with a igition switch that has 2 differant fuel settings (normal octane & preminum). The instructions that came with the tether switch does not mention this type of ignition...
Not sure if this helps...but my bro has a 01' RMK and it says to only use premium gas, I believe he may have tried to use regular or even mid grade and it bogged or started to. Never the less...I think that it is always best to run premium in high perfomance "toys" like smowmobiles and such...
Oct 18, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
1,092 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
