Question about Canon PIXMA iP90v InkJet Printer
Black ink will not print with canon pixma ip90v
Tried cleaning and deep cleaning....still nothing in black. when I do the print test, the black blocks will print, but some of the lines are missing, otherwise when I try to print with black, it doesn't work. Color prints fine. Wondering if this is worth trying to get repaired (and where to take it). the printer is 2 years old. thanks for any help you can provide.
  • wildolive Jan 30, 2009
    thanks, I did contact canon and since the warranty is up, they will not replace it. Still trying to find a solution.
  • Printless1 Mar 27, 2009
    Changed the black cartridge in my IP90v and now it won't print. Neither cleaning nor deep cleaning have resolved the issue.
  • 214 Answers
Try sending Canon an email through their support website. I had same problem exactly, mine is 1 year old. They sent out a replacement unit for me today. It's worth a try.
Posted on Jan 30, 2009
Black and red ink missing on the paper
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 04, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Nothing is printing. It looks like there is no
    Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
    To print a nozzle please refer to chapter 12 page 115 of the manual,
    If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
    You can download the manual here:
    http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
    Nov 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
    When it prints black cant hardly see,if i print a color and black and white you cant see black print
    Common error for Printhead that some colors on your printout are missing.
    1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
    2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
    3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
    4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
    Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Test page prints fine, but nothing else does
    You need a new printhead, QY6-0049-000 around $40.00. Your printhead has worn out or plugged nozzles and cleaning won't help.
    Jul 09, 2009 | Canon i860 InkJet Photo Printer
    #5 black ink cartridge skips through the middle occasionally
    Replacing the print head
    The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
    • The nozzle test appears broken or to have horizontal white streaks.
    • One or more of the colors is missing from the Nozzle Test.
    • The colors are incorrect on the Nozzle Test.
    • A print head error is indicated on the unit.
    • The printer powers off when the print head is installed.
    I hope it helps!!!
    Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Canon PIXMA iP90v InkJet Printer Logo
    178 people viewed this question
    old marine
    old marine
