I am wondering, can you plug a plain power strip (no surge protection) into a battery backup.  I just want to use it as an extension cord for my laptop.
  • 114 Answers
Yes sure. No problem. As the battery backup (UPS) has its own surge protection for the output anyway. :)
Posted on Jan 30, 2009
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Powermac G5 screen shaking
    This sounds possibly like a power related issue. If you are using a simple power strip to plug into, consider replacing it with an Uninterruptible Power Supply (aka Battery Backup, UPS). AC power related issues can cause screen waviness or shaking. Be sure to obtain the proper capacity unit for your needs. These units are rated in Volt AMPS and come in sizes from 300VA to 1500VA in the consumer product line. APC, Belkin, Triplite, CyberPower are some popular brands. The VA capacity to choose should be considered over price alone. Buying the cheapest one vs the right capacity can result in not having a unit capable of protecting your devices plugged into it. Understand these have 2 primary functions,
    1. surge-protection
    2. battery backup during a power related problem
    There are 2 different banks of receptacles on these units.
    1. Some for surge protection AND battery backup
    2. Some for surge protection ONLY
    Your computer would be plugged into the surge AND battery backup receptacles. When a power related incident occurs, the unit quickly switches the devices plugged into these receptacles off of AC power to the batteries, until the power issue is resolved. The time on battery is limited based on the VA capacity mentioned earlier in this solution. So buying the largest VA capacity unit you can afford will simply give you more available time on battery before the batteries are exhausted and must be recharged. On the other hand buying the smallest VA unit could result in an immediate and unexpected shut down of the computer if a power related issue occurs and the battery backup cannot handle the devices plugged into it. NEVER use these units for battery backup of Laser Printers or other high curent devices. These can destroy the battery backup.
    I hope this helps with your screen issue.
    Apr 15, 2013 | Apple Power Mac G5 Desktop
    Replaced conext ups cnb325 battery but power indicator light does not come on.
    There is a solder problem on some units. Remove the battery and the 4 screws, tilt the lower panel away, and let the circuit board drop out onto the workbench. WATCH FOR THE TRANSFORMER, it is not fastened. Inspect for a loose solder connection, and if you find it, re-flow the solder. Re-assemble and plug into the AC current to charge the battery.
    Jun 01, 2012 | APC Conext UPS System
    Need to know how to place extension cords for outdoor ice lights on roof edge of house
    Hello, you can use a terminal strip power surge outlets. It will have many outlets on it that then go into one cord that will plug into the outdoor outlet.
    Dec 06, 2011 | Heating & Cooling
    Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
    Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
    Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
    I have a gateway desktop computer. Recently moved
    Before you actually replace the power supply, check some other things first:
    1. Wall socket
    2. Power strip/surge protector
    3. Power cable
    4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
    5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
    If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
    If everything is secure and the problem persists, replace the power supply.
    Nov 27, 2009 | Office Equipment & Supplies
    Battery Backup/Surge Protector Question
    Considering the low draw of power you intend for the UPS it will work well. I have two monitors on a strip plugged into UPS along with desktop, routers and modems, UPS handles all well, it's just shortens battery backup times. Have had to power down from outages several times without any probs.
    Jan 30, 2009 | APC Back-UPS RS Battery Backup (apw...
    UPS issues with bad power
    First, most of the UPS sensitivity can be adjusted. Setting a higher sensitivity will make the UPS compensable much faster if the current goes to high to too low thus always providing a good power quality to the equipments. For example, on a BackUPS RS the low level can be configured from 94V to 104V and the high level from 126V to 136V. An entry-level UPS such as the APC BackUPS ES will switch to battery mode as soon as the power goes out of the sensitivity range. On the other hand, a high-end UPS for workstation like the APC BackUPS RS has a feature called Automatic Voltage Regulation (AVR) that compensate at some extent without requiring the battery; this makes the battery last longer before needing to be replaced.
    Second, most of the UPS have "Battery Protected" and "Surge only" outlets. Make sure that the computers are connected to the "Battery Protected". The "Surge only" outlets will only protect from parasites or surges like a thunder storm. They should be used for less important stuff like a desk lamp or devices with high demand peek such as a laser printer.
    Third, the use of a power bar connected to the "Battery Protected" side should not have any impact as long as it is not overloading the UPS. Personnaly, I have a power bar connected to both my UPS.
    Feb 06, 2008 | APC Smart-UPS UPS System
    Computers & Internet Logo
    David Payne
    David Payne
