Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Technician states that we need to replace 8 yr old Amana Refrig
We did some self-diagnosis before calling tech. Freezer stopped cooling. We check the frost pattern on the coils inside freezer. The pattern was uneven, so we thought it was something other than defrost thermostat. Fans were all running and so was compressor (it was hot to touch). We had a tech come out and he said it was a compressor issue, so he replaced it. Next day, freezer still wasn't cooling properly. We called tech and he came out and said he needed to flush coils. I don't understand what needed to be flushed. After that, the freezer cooled to 0-10 degrees, but then into the night started warming up again. We called tech again and he said coils have most likely filled with sludge again and refrigerator is shot. We should buy a new one. I'm not ready to give up based on one opinion, so I'm looking for another opinion to say I need to replace or tell me there is a way to fix our problem.
  • wendanra Jan 30, 2009
    Thanks for your quick and honest reply. Since we already spent $300+ for replacement compressor and service, it's probably a better idea to buy a new refrigerator, instead of continuing to dump money into a 8-yr refrigerator. They sure don't make them like the old days. My mom's lasted for 15-20 years at least. The technician was respectable in that the company is refunding us the cost of the compressor and only charging us $40 for the service call.
  • 410 Answers
Without physically looking at unit and going on what your saying I would say the unit has a restriction in the sealed system. this can be fixed with the correct steps and techniques. the biggest question is expense and only you can determine that. Here are the steps necessary.
  • Isolate evap heatexchanger  assy flush with refrigerant and high pressure nitrogen to clear all oil and contaminants.
  • Isolate condenser and follow same steps as evap heatexchanger.
  • replace filter drier
  • Evacuate sealed system with good vacum pump
this is a time consuming process and quite honestly expensive. Hope that helps thx peyton
Posted on Jan 30, 2009
  • peyton thompson
    peyton thompson Jan 30, 2009
    Sounds like you have an outstanding service company please send tehm all the business you can. I agree with you about refrigs not made like they used to be but its all we can get.
    Have a great evening and God bless!!
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
My refrig just stopped cooling/freezing. 6/7 yr old side by side Amana asd262rhrw. the motor has been louder lately
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jun 03, 2011 | Refrigerators
Have a 17yr old amana energy saver frig. freezer on bottom. freezer works fine, but no cooling in refrig.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Nov 25, 2010 | Amana Refrigerators
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
Refrigerator is not cooling
Good day,
You will need an ohm meter to check the parts.
Your defrost system has failed.
It is made up of 3 components, 2 of which are located behind the rear panel in the freezer compartment.
Remove the rear panel. There is a cooling coil, that has a calrod heating element that runs along it's bottom. As well there is a defrost thermostat ( a small round 1" disk) which is located on the top of the same coil. Both should be checked with an ohm meter to test for continuity. The heater should read no more than 30 ohms, the thermostat ( IT MUST STILL BE COLD BELOW 30 DEGREES) should read zero ohms. Note: The heater rarely fails, the thermostat has a high failure rate.
The third item is a timer, or a solid state adaptive defrost control. Depending on age, and model, it is located , behind the kick plate on the bottom front.
Or, in the fresh food compartment on the roof.
If it is a timer, you can turn the timer shaft when the machine is running until the machine shuts off. With it still turned on, wait 40 minutes.
If the machine turns itself back on, the timer is O.K. if not, the timer is bad, and needs replaced.
If the Main heater checks O.K. and it has a solid state control, then replace the thermostat in the freezer compartment, and the solid state board.
Below is an excellant tutorial on defrost systems.
Thank you for using FixYa
Jan 20, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Control Board Programming Code
the code is most likely printed on your model number label located inside the refrig compartment and entering the code instructions are on your tech sheet that is taped to the underside of your refrig.
remove the toe grille and feel under the cabinet for a plastic bag/envelope taped to it. just follow the instr for entering the code..
ps if the code isnt on the model label it may be on the tech sheet..
Dec 18, 2007 | Refrigerators
Freezer is not freezing...
2 possibilities one is a bad start relay on the comp or the comp could be bad. the relay is faily inexpensive and you should be able to replace it your self if the compressor is bad it will require a technician. good news is the refrig is under 5 yrs old and the compressor should be in warranty still
Dec 14, 2007 | Jenn-Air JFC2087HRP Side by Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
130 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
