Question about Mitsubishi VS-45605 50" Rear Projection Television
Need help repairing Mitsubishi VS 4541 rear projection TV
The TV has great sound but no picture I took off the back panel the bulbs are fine they all work red,blue and green the mirror is fine and all the boards look ok please help I was thinking the video processor but I have no idea where it is located.
  • 3 more comments
  • Anonymous Mar 26, 2008
    sound
  • hobaugh May 21, 2008
    no picture but there is sound
  • Anonymous Apr 02, 2009
    i have this vs-4541 model. it worked atmy friends house and they
    brought it to mine. its getting sound but now no picture. i took off
    back side and looked around i dont see anything broken or
    out of place. can someone help me, i think their reomte is the issue
    to get to have veido, but now after reading i am thinking something
    must have got bumped in the transportation.
    anyone please give me ideas of what to do or call
    and i need a manual too. my number is 614-975-9069 thanks
  • DragonRe Apr 22, 2009
    Lectra, did you ever get a hold of a service manual? Mine is doing the same thing.
  • shawn_thorni
    shawn_thorni May 18, 2012
    I have a mitsubishi vs 4541 unit powers up for an hour and then the picture goes out but i still have great sound i did clean it all out it seemed to help but it still shuts off
    Problem Solver:
  • 4 Answers
I have the same type of TV, and I think it has a filed "power rail", as the LED does not burn at all, nor do the heaters of any of the CRT's. When I plug it in, I can hear the relays click in, and hitting the power button will cause the relays to click. Other than this, there is no sign of life from this TV. I really would like to find a repair manual or a schematic to aid in troubleshooting. The self-diag trick may be handy if the LED would come on. I'll try it and see what it does.
Posted on Sep 09, 2007
  • Roger Gilbert Sep 09, 2007
    Nothing. I have a test button, two input buttons (an up and down), and two adjust buttons (up and down). No menu button, and no remote (it may come with one, but I got mine second-hand). Schematics would really help me here.
  • Roger Gilbert Sep 11, 2007
    Fixed it! Turns out that an RF-stopper inductor (basically a wire wound a couple times through a ferrite bead) has become partially unsoldered, and the connection heated up hot enough to fricassee the board (turning it dark). Simply resoldering the connection brought this TV back to life.
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Posted on Aug 21, 2007
I have a mitsubishi vs 4541 projection tv, with no picture, just sound
Posted on Sep 22, 2008
Got a Mitsubishi vs-8070, everything works fine then the screen turns off after about 15 minutes sound still works fine. Help.
Does this unit have a projection bulb in the back end of the set? Just based on my experience with a friend's 65 inch rear projection TV, there might be an indicator light on the front panel that may blink if the rear projection bulb is failing. If there is a failing bulb it could account for the screen going black with everything else just fine, after the bulb gets heated up in 15 minutes.
Oct 15, 2014 | Televison & Video
Mitsubishi VS-50501 no picture sound works great
Odds are real good that the solder connections on the deflection yokes are bad. Go through the front access panel and with a small mirror look and the back side of the connector on each yoke. The top two pins of each will probably show 'ringed' solder connections.
May 07, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
NEED TO REPLACE BULBS IN mITSUBISHI VS 45607 cAN NOT FIND THEM
This doesent sound like a bulb problem to me at all! it sounds like a few capaciters need replaced! Look put the screwdriver down and call a pro because you could ruin the set trying to do a minor fix and causing a major problem!
Dec 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
Mitsubishi VS-4541
clean it out it is over heating, use a air hose to blow all the dust out
Sep 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
1,944 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
