Question about Samsung HLN617W 61" Rear Projection HDTV
No picture but sound once it goes off there is 3 blinking lights
Samsung 61' model hln617w no picture but sound once its off there is 3 blinking lights..
  • 139 Answers
Most likely for this symptom is the lamp. If you'd like you could sit behind the set and have someone turn it on, you should hear the color wheel spin up and then you should hear the ballast try to fire the lamp, it makes a small arcing sound. If the lamp doesn't light the process starts over again.
Posted on Mar 27, 2009
My HLN617W dlp will turn on with no picture (sound is OK), then will seem to turn off, then back on again without me doing anything. After this ritual being repeated, the lamp and power lights will start...
The lamp is finished. Order a new lamp using the code on the side of the TV. Remove the lamp door on the back of the TV (4 screws) and then remove the lamp (1 screw). Have a look at the lamp... is it damaged? See my tips & tricks if you want to learn more about the lamp.
Mar 18, 2010 | Samsung HLN617W 61" Rear Projection HDTV
There is grinding noise; bearing rubbing against something. Samsung model HLN617W
The light engine is bad if its grinding. Squealing or a loud Vibration buzzing sound would indicat the color wheel
Nov 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Feb 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Picture does not show but there sound to it and then it shuts off
Sounds like your bulb is out, Start there and post back again or email me if you need more help. Cfoley@hawaii.rr.com
Jan 20, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
3 blinking lights no visual...just bought new color wheel
recheck those plugs from color wheel to dmd bd, when was the last time you replaced the lamp?
Oct 18, 2007 | Samsung HLN617W 61" Rear Projection HDTV
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
244 people viewed this question
Henry  Thomas
Henry Thomas
