Question about Panasonic PT-47WX49 47" Rear Projection Television
Strange series of bowed lines in the picture
I am a bit of a novice with this...but basically my problem is that there is a series of bowed lines that have suddenly appeared in my picture...they are green and run horizontally but with a slight bowing effect...just slightly below the green is a ...someone told me that this may be dust on the lenses...does anyone have any idea what could be causing this?
  • Eric Markiewicz Jul 28, 2007
    I was talking ot you live a minute ago...can you tell me how to exit the service menu...I am trapped in it...and can't get out?!
    President:
  • 3,130 Answers
Nope, not dust on the lens, but you have two IC's in the convergence correction circuit that have to be replaced. you shouls get the service manual for this set, as well as go to www.servicemanuals.net to find the download but also go to www.mcmelectronics to get the STK convergence IC's. If you have no solid state printed circuit board repair experience, I highly advise you to call in a pro to assist you in this repair. Good Luck
Posted on Jul 28, 2007
How to pick the right poundage for my recurve bow?
In a recurve bow, the longer your arms the further you pull the bow back and the higher the pulling weight of the bow becomes as you pull it further and further. A starting bow weight is around 25-31 lbs.
Aug 26, 2012 | Betsey Johnson Archery
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
Picture bows in towards middle
YOU HAVE A ALIGNMENT PROBLEM, ON YOUR BOW OR PINCUSION, OR A BAD RESISTOR, THE COLORS NOT LINING UP COULD BE A CONVERGENCE PROBLEM. I ADVISE YOU TO LET A EXPERT TO THIS DUE TO THE HIGH VOLATE ON THE CRT(PICTURE TUBE)
Jun 07, 2009 | RCA Televison & Video
Screen
Yes you need to replace both of the convergence amp ICs they are STK392-040 they need to be solderdbut its basic soldering nothing too advanced. You can get new ICs at the following link and they include free instalation instructions with pictures so you can do the repair yourself, and they also have free on line instant messageing when you do the repair in case you have any last minute questions. heres the link.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Samsung HCL4715W 47" Rear Projection...
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Sep 08, 2007 | Mitsubishi WS-65819 TV
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs, have a basic knowledge of electronics and be able to use a soldering iron. You will also have to do an alignment through the service menu.
Apr 01, 2007 | Samsung HC-P4752W 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
